Changing Foglight Bulb in 1992 Camaro Z28 : HOW?
Old Oct 16, 2013 | 02:28 AM
camarosource's Avatar
Car: Custom 1992 Camaro Z28 25th Anniver
Engine: 5.7L V8 350 L98 TPI
So today I tried to change the foglight bulb myself and I was shocked that it's not easy!
I tried from the front reaching my hand thru the grill thru the foglight opening and then realized I needed to be double jointed to curl my wrist backwards to grab and twist the socket.
I then used two hands one on each side and used a finger on each side of the socket but then you have the button you have to press at the same time while turning so that didn't help.
In fact I nearly cut my wrists getting my hands BACK out.
So I tried from behind.. Put it on a lift and thought I could just reach under.. Course that didn't work as the Baffle is completely covering access.
Removed the deflector to be able to get more room to reach my arm thru the two ducts themselves as your shoulder hits it. It allowed SOME more room but still you are completely blind.
Mechanic was watching and took over and he cursed (under his breath) the whole time ending up taking 30 mins to do this!
He was stumped and all he could do was do the same thing as me and reach thru the ducting under the car behind the foglights themselves. This means your entire arm is inside and can barely reach inside to the end and then have to twist the socket.
Was a REAL PITA!!!
I've looked in Chilton (while says "foglamps" in the index for 6-35, there is infact NO mention of foglights in the manual; just headlights). And Hayes doesn't mention it either.
Googles results with nothing except a IROC-Z video from 1aauto except for the fact that ALL trim under the car was removed..
Old Oct 16, 2013 | 02:41 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: Changing Foglight Bulb in 1992 Camaro Z28 : HOW?
Can you remove the adjusting screw and tilt the lamp downward to expose the socket?
I haven't really checked but now that my filter boxes are gutted I think they can be reached can be reached through there once the filters are removed.
Old Oct 17, 2013 | 12:44 AM
No there is no room to tilt the lights if you loosen the adjuster and plus you would have to readjust it again.
If you take the filters out, there is no access to the foglights.
Old Nov 2, 2013 | 03:13 PM
DBLTKE's Avatar
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
It is A LOT easier to just remove the fog light entirely, replace the bulb, and reinstall.
Old Nov 13, 2013 | 08:28 AM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
its best to just unbolt the two mounting bracket bolts and remove the fog lights from the car. to change the bulbs
Old Nov 13, 2013 | 08:59 AM
Dakota W.'s Avatar
Car: 1991 Christine Z28
Engine: RV Cam and Intake 350 SBC
Transmission: 5speed
Axle/Gears: 3.08 ls Posi
It's pretty easy to do with gutted air filter boxes
92camaroJoe
Jul 29, 2023 07:57 PM
Vintageracer
Jan 10, 2020 05:33 PM
92camaroJoe
Aug 13, 2015 06:07 AM
greeny
Wheels and Tires
Aug 12, 2015 03:55 PM
