mechanical gagues?
Old Nov 5, 2001 | 01:17 PM
Bobbyz's Avatar
Car: 87 IROC Z "ZZ4"
Engine: 350 "ZZ4"
Transmission: ck performance th400 3000 stall
Axle/Gears: 3:73 10 bolt
mechanical gagues?
has anyone ever ran mechanical gagues in a camaro? i have a 85 z swapped motors and now trying to run the oil pressure line and water temp line. any easy route to go? also i put the gauges in the middle under the dash vents. thanks
[This message has been edited by Bobbyz (edited November 05, 2001).]
Old Nov 5, 2001 | 07:11 PM
superstreet's Avatar
I put an oil pressure,a boost,trans. temp and coolant temp. gauge in my car.2 are in the spot where the radio was and the other 2 are where you mounted yours,under the the dash vents.I took the top of the dash off,drilled a small hole to route the lines through to go up into the dash then fed it down through the center of the front of the dash (closer to the windsheild) and pulled it out by the brake pedal and through the fire wall next to the wire harness.It's not really that hard,just a little time consuming.
Old Nov 7, 2001 | 12:26 PM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
I have Autometer mechanical gauges (oil pres and water temp)mounted under the center vents, angled towards driver.Ran lines through top of console/heater control area.Drilled hole above right side of gas pedal to feed into engine compartment.
-Rich-
Old Nov 7, 2001 | 01:18 PM
Bobbyz's Avatar
Engine: 350 "ZZ4"
thanks guys. looks like i will be doing some drilling today .
1985 z28 ( under construction)305/700r4,edelbrock performer intake/cam,holley 600cfm carb,dynomax headers, 3.23 rear,autometer gagues, edelbrock valve covers
Lbibb
May 5, 2016 12:00 AM
sjorgens
Oct 1, 2015 07:54 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
dbrochard
Interior Parts Wanted
Sep 28, 2015 07:40 PM
mfp189
Sep 27, 2015 09:25 AM
