floor pans
Old Nov 5, 2001 | 06:58 PM
jcamaro's Avatar
floor pans
has anyone ever use bondo on rust holes in floor pans. let me know how it worked
Old Nov 6, 2001 | 03:07 PM
RSRagtop's Avatar
Bondo isn't the right way to fix rust, it usually only makes the problem much worse alot faster. Bondo won't flex, so it will likely just pop off the floor the first time you fly through a corner. Sorry to rag on you man, but at least you didn't find out the hard way. You could use fiberglass, it will work OK but its still not the best choice, the best solution is to cut out the damaged areas and weld in new metal. Repop floor pans are avaible from places like Year One. Whatever you end up doing, make sure you get rid of all of the surface rust too. Good luck.
Old Nov 7, 2001 | 07:31 AM
jcamaro's Avatar
thinks a lot i was wondering if it wold work and it would be a shortcut to all of the work of cuting,grinding,welding.
i just want to get it done by spring i am doing a gut job (all it is right now is the body)thinks i will be cuting,grinding,and welding
Old Nov 9, 2001 | 07:43 AM
The_Maniac's Avatar
If you want pics of an actual floor pan replacement job (along with a shopping list of materials), check this part of my site:
http://www.lightstream.net/~the_maniac/floor.html
-Jason
'84 5.0 liter v8 Z28 Camaro
'93 3.3 liter v6 Grand Am SE
E-Mail: The_Maniac@lightstream.net
Old Nov 9, 2001 | 09:32 AM
bradkeith's Avatar
IF it's just a small hole, just cut a square of sheet-metal, grind your hole out and weld it on. but don't forget to paint it or cover it though. A friend of mine has a 78 chevy truck and he put new floorpans in and left them as bare metal...they lasted about a year!
1986 camaro with 92z28 gound effects, aero wing, 17in American Racing Pythons w/275'40's 4 3/4 Unlimited products cowl, 3.90 auburn gear rear-end with Steve Spohn adj LCA's,Panhard bar. 406 stroked to to 429 motor in the works.
1989 Iroc-z 5.7 white t-tops, 3.42's megashifter, 2 1/2 harwood cowl.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
LC2 TECH
Oct 13, 2015 11:53 PM
88CamZ
Oct 8, 2015 10:29 AM
loud91rs
Oct 5, 2015 10:05 PM
skinny z
Oct 5, 2015 06:23 PM
