Window Rattles
Window Rattles
When I have my passenger windown down any where besides all the way it rattles. I have taken off the door pannel and I cant see anything to adjust. I tried to tighten the felt guides at the top but still it rattles. Only thing that did was make it a little tuffer to roll up or down the window. Any one got any ideas?
1989 RS Camaro
305ci TBI
Mods:
Hedman Header
Highflow Cat
3inch catback pipe
FlowMaster 80 Series Muffler
14x3 Open Air Element
8.5 HighTemp Spark Plug Wires
4.7 Ohm Reistor
Torque Converter Lock Up switch
www.rit.edu/~cjp8408
AIM: PopaPork
1989 RS Camaro
305ci TBI
Mods:
Hedman Header
Highflow Cat
3inch catback pipe
4.7 Ohm Reistor
AIM: PopaPork
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Seems to be a common problem.
I have yet to find a sure fire way to fix it.
John
G O D BLESS AMERICA
http://www.3rdgenformula.com
87 Formula 5.1 TPI Auto Modified (Yellow/Black)
87 Formula TPI (5 Speed) Yellow/Gray STOCK
14.8sec 1967 Buick Riviera
1990 Buick Riviera (driver)
83 Camaro
83 T/A
John
G O D BLESS AMERICA
83 Camaro
83 T/A
i had the same problem and took the door panle apart a few times and tightened things or adjusted them and never could get it to stop rattleing but then i looked around and figured out it is the upper reinforcement bar in the door, i put a few rubber washers between it and the outer panel then siliconed them in. now i can crank the stereo and not rattles, hope this helps.
89 Rs camaro
305 tbi
3in flowmaster muffler
manderal bent pipe
no cat
ELECTRONICS
viper alarm
pioneer 4-way 6x9's
15' orion sub in a bandpass box
300x1 kenwood amp
180 watt JVC cd-reciever
89 Rs camaro
305 tbi
manderal bent pipe
no cat
ELECTRONICS
viper alarm
pioneer 4-way 6x9's
300x1 kenwood amp
