86 camaro upper door hinge worn
Old Nov 19, 2013 | 05:09 PM
havacamaro's Avatar
Car: 86 camaro iroc z
Engine: 355 LT1 Full Roller
Axle/Gears: 9 bolt 3.73 posi
Hey guys, I have replaced with new bushings and pins top and bottom, and still have really bad sag, You can see the hinges are worn really bad when you move the door up and down while open. Anyone have any suggestions other than replacing the upper hinges?
Old Dec 1, 2013 | 01:11 AM
85-87IROC-LB9s's Avatar
Car: 1985 IROC-Z/1987 IROC-Z/1988 IROC-Z
Engine: Four 305 TPI LB9's
Transmission: Two 700R4's/One WC T-5
Axle/Gears: Posi's 3:42/2:73/3:55/2:73
Re: 86 camaro upper door hinge worn
Hello, when you mean both top and bottom hinges, do you mean you replaced the upper pins along with the usual lower pin with bushings? If you didn't do the upper hinge pins then that would most definitely be your problem despite replacing the lower pin. If not then perhaps the hinges need to be bent back into shape, but from the sound of things your top pins have failed like every other third-gen. A few searches on this site will get you to helpful threads already covering this topic. Top-down solutions would help solve your problem for the upper pins and doors in general.
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
86IROC112
Apr 9, 2016 10:20 PM
BlackTopKing
Aug 19, 2015 12:13 PM
