Help! accidentally gouged my fiberglass spoiler, how do I fix this?
Car: 1989 Trans am GTA
Transmission: t56 6 speed
Axle/Gears: 3.45
I was dry fitting my hawks wrap around spoiler before paint and while fitting it on, one of the clips gouged the underside/side of the spoiler on the wing. What should I do to fix this? I was thinking bondo but I don't know how well that would stand up to chipping etc
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: Help! accidentally gouged my fiberglass spoiler, how do I fix this?
Wow!! that sucks,if I were you,I'd take it to a body shop.You already have $400++ into it,another few more bucks won't hurt.
Axle/Gears: 3.45
I got some bondo type stuff with kevlar strands in it to repair it, looking good so far! will post pictures when I'm done
Axle/Gears: 3.45
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
Don't need the whole fiberglass kit, just gelcoat would probably do it. Make a mold for your repair using wax paper to minimize sanding afterwards.
Did you hit it hard? Shouldn't chip easily, maybe a void in the fiberglass?
I'm disappointed, but not surprised, that they are using polyester resin on such a large expensive part, really should be epoxy.
Axle/Gears: 3.45
I'm not worrying about it anymore because I pretty much fixed it back to 100%. What happened was, I was adjusting one side and I guess as the other side was moving it got snagged on the sharp side of the clip on the hatch and just pretty much ate into it
Hotrodboba400
Dec 10, 2019 07:07 PM
CAMAROBEAV
European Region
Sep 12, 2015 09:34 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
