Need some help adjusting T-tops
Can anyone give me detailed instructions on how to adjust the T-Tops. They are making alot of wind noise on the highway. I think my are the lexan glass. Any pics would be helpful.
92 Camaro RS
305 TBI
T-Tops
DynoMax Cat-Back Exhaust
Gutted Cat
Hypertech Street Runner Chip
K&N open element
Custom Interior
Window Tint
Prestige Alarm
Foglights
JVC El-Kameleon Head Unit(w/ remote)
Pyramid 6 x 9's
(bass blockers)
Jensen 5 1/4's
2- 10" Kenwood Tornado Subs
Pyramid 600 Watt Amp
Best ET: 15.976 @ 86.01 mph
reaction time: 0.479
60 ft: 2.269
92 Camaro RS
305 TBI
T-Tops
Gutted Cat
K&N open element
Custom Interior
Window Tint
Prestige Alarm
Foglights
Pyramid 6 x 9's
(bass blockers)
Jensen 5 1/4's
60 ft: 2.269
I think they will always make some noise that is just the way ttop cars are. My mom had a 97 firebird new and the ttops were noisy in it too. Not as bad as my car but still pretty loud.
91 z-28 305 700R4
3.73 gears out back
T-Tops and Black all over.
91 z-28 305 700R4
3.73 gears out back
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Adjusting them is pretty easy...
If your car has all the correct screws, then this is how it should work:
take a #2 phillips screwdriver & remove the interior trim pieces in the front & rear of the T-top. NOTE: It may be possible to adjust the tops without removing the trim pieces IF you can get clearance to get to the nuts on the cams.
Once you have access to the cams you take your favorite 7mm nutdriver & loosten the cams a little, then move them down to allow for a tighter fit.
As for the Plastic T-tops, the fast & easy way to tell is the front & rear edges of each Top will have a metal strip. No strip- there glass...
G O D BLESS AMERICA
http://www.3rdgenformula.com
87 Formula 5.1 TPI Auto Modified (Yellow/Black)
87 Formula TPI (5 Speed) Yellow/Gray STOCK
14.8sec 1967 Buick Riviera
1990 Buick Riviera (driver)
83 Camaro
83 T/A
G O D BLESS AMERICA
83 Camaro
83 T/A
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
IROCZDAVE (88-L98)
Exterior Parts for Sale
Sep 22, 2015 08:28 PM
