Questions about my Berlinetta
Old Dec 4, 2001 | 04:06 PM
Syrin's Avatar
i just got this car, its an 84 berlinetta with a 350....im jus curious the speedo and the tach doesnt work, how do i fix this? is there a fuse maybe or do i need a whole new front gauge plate?
Old Dec 4, 2001 | 06:34 PM
1986CamaroSCteen's Avatar
Check your fuse panel, I dont have a berlinetta so i dont know, but i would advise you right now to rip out that digital and add all analog in it, you'll be glad down the road. If your fuse is good, there might be some problems with the wiring, check it out, if its all in order, then you can buy a new one, if you cant find it in part stores you can order factory direct, if you call chevy, ask for a restoration kit, it will tell every part the car had stock and you should be able to order the parts from them
Old Dec 5, 2001 | 07:51 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Ripping out the digital dash and installing an analog is not that "simple".
In order to do so - you would need to replace the entire dash housing, floor console, heater boxes (both side of the firewall), steering column and various other parts.
If you don't have any luck in finding a dash - conact me,.... I usually have a few hanging around.
P.S. Regardless of where you get the dash cluster from - be sure it is the right one for your car!!! There is a differance between the V-6 and V-8 dash cluster !
John in RI
Webmaster@Berlinetta.Info
Old Dec 5, 2001 | 11:27 AM
kiztope's Avatar
Car: 92 Formula
Transmission: A4
Sorry, but I am curious,
Did you put the 350 into it??
http://kiztope.50megs.com
92 Pontiac Firebird Formula WS6 5.7/A4
K&N, Blue Streak Cap and Rotor, strange unknown exhaust system (sounds good though)...
Mods are in direct proportion to income!
92 Rs 3.1/T-5
Beautiful car, many mods, but now I am turning attention to the 'bird!
AIM : Theonekiztope
ICQ: 8787542
"Maybe one day life will take a turn. When it does Lean into it!" Leon Calrinsky (98)
Old Dec 10, 2001 | 10:17 AM
John in RI's Avatar
For what it's worth -
I had some dash problems after a V-6 to V-8 motor swap one time a few years back..... But I believe that was due to the "help" I had with the project. Even after installing good working (tested) dashes I could not get the digital readout to display a speed. (It was always showing '0' MPH !) I' think this was a result of damage to the speed sending unit at the tranny that my "helper" installed.
I have re-installed a V-8 into Berlinetta's that were originally a V-8 car since that time and have never had dash issues as a result of the engine swap again.
John in RI
Webmaster @
http://Berlinetta.Info
[This message has been edited by John in RI (edited December 10, 2001).]
BlueIroc-Z
Jun 9, 2019 03:22 AM
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
bbernardo94
Aug 19, 2015 05:25 AM
redmaroz
Aug 16, 2015 11:40 PM
