Door Jamb hole question
Old Jul 30, 2014 | 12:05 PM
FirebirdUSX's Avatar
Car: Firebird
Engine: 5737cc
I was detailing today the inside of the car and while taking a break I noticed the plastic cover on the door jamb (got a pic with it) and made me wonder why that hole exists there.If you go inside the car you already have plenty of holes to get inside the rear quarter panel so that hole there makes no sense plus it sits outside the weatherstrip so i guess if you preassure wash the car you can get water inside the body.
can anyone explain the design behind it?Its not important or anything but cant find the logical answer ...oh and yes I did a
Old Jul 30, 2014 | 12:21 PM
simo's Avatar
Car: 1983 Daytona 500 Pace Car
Engine: CFI - 305
Transmission: Automatic-700R4
Re: Door Jamb hole question
The door vents are part of the flow through ventilation system when using the heater, A/C and shutting the doors. They relieve the pressure inside the vehicle.
Old Jul 30, 2014 | 12:57 PM
Car: Firebird
Engine: 5737cc
That makes sense
They looks like a intake for air thou .
Old Aug 1, 2014 | 07:49 PM
greenyone's Avatar
Car: 91 G92 Z28
Axle/Gears: 342
They are also how your access the back side of door striker bolt mounting plate for adjusting your door pin striker.
Old Aug 1, 2014 | 11:48 PM
transaero's Avatar
Car: 1987 Trans Am GTA
Engine: Warmed over 350 TPI
Transmission: 700r4 soon to be t56
The vents also have rubber flaps on the inside; I found this out when I took them out to repaint them. They should keep water out for normal cleaning.
Old Aug 3, 2014 | 03:09 PM
82tarecaro's Avatar
Originally Posted by FirebirdUSX
That makes sense
It is an intake. Cabin air flows into that vent and gets vented out of the car.
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
Out-Cast
Aug 23, 2015 06:33 AM
BlackTopKing
Aug 19, 2015 12:13 PM
redmaroz
Aug 16, 2015 11:40 PM
