Replacing inside of door on 91 Pontiac Firebird
Old Aug 13, 2014 | 04:19 PM
corey8084's Avatar
Car: 1991 Pontiac Firebird Formula
Engine: 5.0 V8 TPI
Transmission: T-5 5 Speed
I tried google, but found nothing so here I am. My passenger side window recently stopped going up all the way and after removing the panel, I found the issue: the motor/regulator rivets that hold it to the door had been drilled out and replaced with nuts and bolts. this is perfectly fine, in fact I'm glad they were, but the top one had ripped the inner portion of the door and crumpled it. so while the motor things it's rolling the window up, it is actually just moving itself a little due to that peace, effectively, being loose.
the obvious answer, to me, is to replace that whole thing, but all I can find is the exterior door shell, without the inside peace. anyone know where I can find it? if not, this car may very well find it's way to a junk yard.
Old Aug 13, 2014 | 10:52 PM
Eric-86sc's Avatar
Car: 90 formula, 89 formula 350 vert
Engine: 305, 355
Transmission: T5, t56
Axle/Gears: 3:45 9 bolt, 8.8 3:73
Re: Replacing inside of door on 91 Pontiac Firebird
You could just weld a washer to where the hole is and use one bigger than the tear. Or at worse replace the whole door which shouldn't be to hard to find another door in California. I wouldn't scrap the entire car over one minor problem.
Old Aug 14, 2014 | 08:37 AM
stealtht/a's Avatar
Car: 1985 Trans Am T-Top
Axle/Gears: 3.42 posi 1LE 10 bolt
You aren't going to find a half a door shell and it's way more work to replace than to fix the problem you have.
Either replace the whole door or weld or otherwise reinforce that spot.
Old Aug 14, 2014 | 08:03 PM
corey8084's Avatar
Engine: 5.0 V8 TPI
maybe what I saw for the outside of the door was a mistake on my part then. I don't have a welder available or I would have no problem just repairing it. I don't live in California anymore (just moved last month) and finding junked cars is quite a bit more difficult in Louisiana. as far as wanting to junk the car, that was about 70% insane frustration at the situation and 30% just tired of fixing one thing and finding three more things that are wrong.
Old Aug 15, 2014 | 04:01 AM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
Could also use body glue to add an extra sheet of metal.
Old Aug 15, 2014 | 07:02 AM
corey8084's Avatar
Engine: 5.0 V8 TPI
will that be strong enough for the window motor? I mean, if it has enough torque to break the metal in the first place, is glue enough to add another one reliably?
Old Aug 15, 2014 | 07:22 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Would it be so hard to take it to a "old school-do it right" body shop and have them weld a washer to it?
Old Aug 15, 2014 | 07:24 AM
corey8084's Avatar
Engine: 5.0 V8 TPI
that means paying someone to do it, huh? it may be my only choice :/
BRoss99
Aug 10, 2025 05:08 PM
jhawkeye
May 25, 2022 06:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
Greg '85 T/A
Aug 14, 2015 01:40 PM
