T-top help !
Car: 92 Z28 Hawaiian Orchid
Axle/Gears: 3.23 Posi
T-top help !
My driver side t-top creaks when I drive it, can anyone help me with this annoying problem ?
Car: 88GTA
Engine: 5.7TPI
Re: T-top help !
Silicon spray will help stop the creaks. Check those plastic barrel inserts where the pins go into. They may be shot.
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Re: T-top help !
Creaks come from two surfaces rubbing together, using a silicone spray should help. Spray Armor-all or something similar on a towel and rub it into the seals. Should help some.
John
John
Axle/Gears: 10 Bolt 2.73 Open
Re: T-top help !
Not necessarily this, but this or something like it...
http://www.nicepriceusa.com/products...licone%20Spray
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
Re: T-top help !
Could try moving the T-top around to try to locate the squeak. IIRC, the T-Top shouldn't move at all let alone enough to cause it to squeak.
Could also try removing the T-Top and extending the pins, then try moving the pins around to see if you can duplicate the noise. that or remove the T-Top cover and look around inside.
I agree on the possibility of the receivers bring cracked or misaligned. They are under the head liner though.
Re: T-top help !
Sorry for the delayed response guys, haven't had the time to try anything out but will try extending pins before laying down some spray. I'll keep you guys posted, thanks a lot for the advice !
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
Re: T-top help !
our cars are notorious for being "flexible". adding sub frame connectors to it will eliminate most of the flexing . which is the root cause of your squeaking.
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
Thirdgen89GTA
Nov 26, 2015 11:04 PM
