Which came first: the window or the weatherstripping?
Old Sep 7, 2014 | 11:33 PM
wildstar's Avatar
Car: 1984 L69 Trans Am
I removed the windows and all of the weather stripping when I had the car painted. Now that I'm putting it all back together, I'm in a Catch-22.
To help the weather stripping (T-Tops) seal properly, the windows should be up.
In order to properly adjust the windows to the correct angles, you need to have the weather stripping in place.
I thought I might install the weatherstripping into the tracks w/o the adhesive, and use them to adjust the angle and height of the windows. Then, I could remove them and re-install with adhesive.
Good Plan?
Old Sep 8, 2014 | 03:29 AM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
Re: Which came first: the window or the weatherstripping?
Good Plan?
no, the windows go in AFTER you have all the weather stripping in place.
Fireslash
Apr 11, 2016 06:43 PM
jrdturbo
Mar 31, 2016 02:58 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
kkirch15
Sep 30, 2015 04:44 PM
