How do I remove locks and door handles?
Old Dec 15, 2014 | 08:53 PM
blktransam's Avatar
Car: 1988 and 1987 Trans Ams
How do you remove locks and door handles? I'm needing to replace them.....
Thanks Guys!
Old Dec 15, 2014 | 10:34 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Re: How do I remove locks and door handles?
You have to remove the inner door panel. Then make sure the window is all the way up and use a 10mm socket with an extension to remove the 2 speed nuts that hold the door handle in place. Unsnap the retaining clip on the door latch rod and remove the handle from the outside. The lock is held in place by a metal U-shaped clip. Use a long screwdriver to pry it off. Unsnap the lock control rod and remove the lock from outside the door.
Old Dec 16, 2014 | 07:31 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The following pic may be of help.
Attached Thumbnails How do I remove locks and door handles?-screen-shot-2014-12
Old Dec 16, 2014 | 09:34 AM
blktransam's Avatar
That's very helpful, thanks guys.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Out-Cast
Aug 23, 2015 06:33 AM
BlackTopKing
Aug 19, 2015 12:13 PM
3rdgenparts
Aug 8, 2015 07:09 PM
