help installing nose emblem(has indent where it goes but the holes were painted over)
Old Jun 4, 2015 | 04:51 PM
509 camaro fan's Avatar
Car: 90 RS
Axle/Gears: Stock
Ok guys, my 90 RS I bought didn't have a nose emblem. I bought one to put back on. My problem is that the holes for the emblem were painted over. My question is how to I open the holes back up without cracking the paint around the emblem.
Old Jun 5, 2015 | 06:46 AM
stealtht/a's Avatar
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
Re: help installing nose emblem(has indent where it goes but the holes were painted o
Drill
Old Jun 5, 2015 | 06:52 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
unbelievable
Old Jun 5, 2015 | 09:44 AM
-=Z28=-'s Avatar
Car: 84 Z28
Engine: 383 Stroker
They must have of filled them with something. I highly doubt just painting over them would cover them so well that you cant find them. I would put blue masking tape around/over where you are going to drill/probe with small sharp object. That will help protect the area and will also make it less likely to tear/chip paint. Remember that the bumper cover is flex-able and if flexed too much will cause paint to spider crack. Who would want to not have their emblem on their Camaro? You got the right one, right?
-Dan
Car: 90 RS
Axle/Gears: Stock
Drilling was my first thought but the bottom hole for the emblem is really close to the edge of the indent and I don't want my custom paint to chip off outside of that indent. I was just trying to see if anyone else has done this and what was their technique.
Old Jun 5, 2015 | 09:47 AM
Car: 90 RS
Axle/Gears: Stock
Cool thanks for the tip. Well I guy I got it from bought from someone who wrecked it. And the previous owner was a paint and body guy so I think he just decided to paint it instead of getting a new one. Yeah I bought it from hawks third gen and made sure it was the correct one.
Old Jun 5, 2015 | 10:10 AM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
Try twisting the drill bit by hand so it cuts more smoothly, or use a hobby razor knife with the pointed tip to carefully cut and separate the paint surface.
Try the inner most hole first to test.
Edit: If it was painted over or filled it, the emblem may not fit properly so check that before hand.
Vintageracer
Jan 10, 2020 05:33 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
69 Six Pack
Oct 5, 2015 07:51 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
