Driving light install Q's
Old Sep 10, 2015 | 07:40 PM
Out-Cast's Avatar
Car: 1987 IROC z
Transmission: 700R
Axle/Gears: POSI 3:27s
Installed a new set of OEM driving light yesterday. There's 2 ways they can be installed. I have them installed like the pic shows or they can switched sides and then they will be pointing to the outside of the car.
Not really sure I like the way I have them now, thinking of switching them around so they point to the outside.
What's your guys preference?
Old Sep 10, 2015 | 11:43 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Re: Driving light install Q's
I have mine pointed straight ahead, but they aren't OEM. If your only choices are in or out, I'd point them out. That way they light up the lines on the sides of the road for in fog or to better see animals(deer).
Old Sep 11, 2015 | 02:17 AM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
To the outside would seem to be correct.
I would wait until its dark and see if the beams cross over each other when pointed "in" and then shine to the out side a bit further out.
Like a "X" pattern.
My preference is to run without them, but then again I don't need them.
Old Sep 11, 2015 | 07:41 AM
Out-Cast's Avatar
Car: 1987 IROC z
Transmission: 700R
Ya I think pointing out will look better. But I'll wait until dark to test them out.
And I took the old ones out but liked the look of the lights being there rather than without.
Old Sep 11, 2015 | 08:03 AM
rce2win's Avatar
Car: 1988 IROC-Z
Engine: 355ci SBC, Holley carb
Transmission: 5 speed manual
Axle/Gears: 4th gen Z28
You have them on the wrong sides. If you swap them around the bevel of the light will match the angle of the front end and send the light correctly out in front of the car.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
justin57
Aug 20, 2015 07:05 PM
Omega
Aug 10, 2015 12:46 PM
