Rust issues
Old Nov 26, 2015 | 09:45 AM
DriftinSSRS's Avatar
Rust issues
Good morning, this is my first post, just joined your forum today. I am about to look at and possibly purchase a 1990 IROC Z convertible with 134k miles. From my preliminary research it looks like rust may be an issue with 3rd gen cars. What are the areas on this car to pay particular attention to regarding rust and what is the best way to uncover the problem areas?
The current owner says there is no rust to the best of his knowledge. This is a craigslist car so you never know.
I posted in the "body" forum to hopefully get good feedback regarding rust but if there are other issues regarding the convertible top, which was replaced in 2010, or mechanically with other systems on the 3rd gens please share your insight if you don't mind.
I currently own a 5th gen SS but miss my 1970 Camaro a lot so this is my chance to get back into an older Camaro. My intention is to drive the car not restore it and turn it into a garage queen.
Thank you and Happy Thanksgiving!
Old Nov 26, 2015 | 10:27 AM
dixie wrecked's Avatar
Car: 91 ws6
Engine: Carb'd 334 stroker
Re: Rust issues
Areas to pay attention to are the front, back, top and bottom.
In all seriousness, the floorboards and rockers. Get underneath and check. Especially if it's a t-top car.
If t-top car, take em off and look around the mounting area/that general area. Might have to pull back the headliner. They leak and will pool water up, slowly eat away over the years, then drip down onto the seats, floorboards..etc.. The trunk pan as well. Never had an issue here. Bottoms of the doors are a biggie..
Basically, same areas you'd look in in all older cars.
Old Nov 26, 2015 | 03:55 PM
phasevariance's Avatar
Car: 1992 Camaro RS & 2014 Camaro SS V8
Engine: 305 & 6.2L
Re: Rust issues
You can usually probe a seller about the cars history.
Does the car have a valid current inspection sticker?
Was the car garage kept?
Was the car used year round?.
No to garage? - probably has some kind of rust.
Car used year round? - Then it was driven on salted roads. - big chance of rot.
Expired inspection sticker? - be very cautious.
Bubbled paint? - rot.
Keep in mind it's not out of the ordinary for 20+ year old cars to have rust. But you need to know if the rot is extensive.
It's not a bad idea to toss a garage 30 bucks for a visual inspection.
Old Nov 28, 2015 | 12:01 PM
Mirror Image's Avatar
Car: 1991 Firebird convertible
Engine: LQ4 ls 6.0
Axle/Gears: 342 Limited slip
Re: Rust issues
Yeah just like they said if possible check inside and out and ill add the battery tray is bad area also
Old Nov 28, 2015 | 01:10 PM
B4C5.7's Avatar
Car: 1989 IROC G92 LB9 MK6
Engine: LB9
Transmission: MK6
Axle/Gears: 3.45
Re: Rust issues
The rear wheel area in the inner wheel wells, where the metal is sandwiched together at the area where inner wheel house meets the upper trunk floor....this area can be a rust area concealed by the tire and undercoating. Three to four panels are welded together in this area, it is not sealed and rust begins underneath at the spotwelds.
Old Nov 28, 2015 | 01:51 PM
Zane M's Avatar
Car: 1991 GTA
Engine: LB9
Re: Rust issues
If you have the ability to weld in the replacement metal, or have a connection that isn't going to charge you shop prices, then it is definitely a worthwhile endevor.
If you have to pay shop rate to get it repaired, then you might be better served selling it to someone who can handle that, and find a better car for your project.
Old Nov 28, 2015 | 11:11 PM
Billgluckman's Avatar
Re: Rust issues
i've looked at many t top cars in the last several months and most had pin holes in the floor pan visible from the underside of the car. The battery trays are also common rust spots. Also pay attention to signs of impact.
TransAm12sec
Feb 16, 2016 06:48 PM
Maadi
Wheels and Tires
Nov 20, 2015 02:38 AM
TransAm12sec
Mid-West Region
Oct 19, 2015 07:03 PM
HoosierinWA
Oct 7, 2015 10:15 AM
gman4dx266
Oct 3, 2015 05:16 PM
