Q: LG4/L69 cowl induction air cleaner lid
Old Jan 1, 2016 | 04:37 AM
Cehbra's Avatar
Car: Red 1991 Firebird with digital dash
Engine: L03 V8 TBI
Transmission: 700 R4
Hi guys
HAPPY NEW YEAR TO Y'ALL!
I have this 84 Trans Am air cleaner lid with the hole in it and it's starting to rust. I want to do a major cleanup. But I can't get this damn thing separated to get to the rust in between. I guess the two dishes are welded together in the middle.
Does anyone have a suggestion on how to get the small inner dish off the outer one without bending it?
Old Jan 20, 2016 | 11:46 AM
navy02ws6's Avatar
Engine: LS1, LB9, L03
Re: Q: LG4/L69 cowl induction air cleaner lid
Have you tried using a heat gun to separate them?
Old Jan 20, 2016 | 03:46 PM
Cehbra's Avatar
Engine: L03 V8 TBI
Thanks! Yes I tried that but nothing happened. Also tried wiggling and heating with soldering flame. I fear that I will warp the metal if I go to acetylene.
Maybe I just try to bore it out
Old Jan 21, 2016 | 09:18 AM
navy02ws6's Avatar
Yeah I'd be worried about applying too much heat to it and warping it. Only other thing I can think of is maybe to let it sit in some kind of solvent or penetrant overnight.
Old Jan 21, 2016 | 01:32 PM
Cehbra's Avatar
Engine: L03 V8 TBI
That could be something. Gonna try that before drilling. Thanks!
Old Mar 12, 2016 | 03:36 PM
Cehbra's Avatar
Engine: L03 V8 TBI
Thought I tell you what I ended up with: I tried with acetone with no luck. So I had to drill it open. Unfortunately the two dishes would separate only at 20 mm, so the hole now is considerably bigger. I covered it with two 1 inch washers that I glued together with 2K glue.
Funny thing is, if you look at the pics, Pontiac actually welded the two blank dishes together and spray painted the assembly only after that. So the inner dish wasn't covered with paint and apparently started rusting badly...
Here are the dishes after sand blasting:
Finished, after bondo, primer and two coats of matte black.
I'm not going to fix the dishes together but rather keep them apart. They hold up fine on the air cleaner like that.
Thanks for all the help!
Old Mar 12, 2016 | 06:32 PM
SolarGoldRaptor's Avatar
Car: 1984 Pontiac Firebird Trans Am
Engine: V8 5.0L HO (L69)
Transmission: B&W T5
Axle/Gears: 3.73 limited slip
That is really strange, mines were separate and I've never seen them welded. Though it does make sense to keep them together otherwise the air cleaner is usless without the inner plate.
Jon92TA
Southern California Area
Feb 22, 2016 10:53 PM
5 speed
Jan 4, 2016 11:48 AM
IntimidatorZ28
Wheels and Tires
Jan 2, 2016 02:53 PM
Irockthedrag
Dec 31, 2015 08:36 PM
koolz
Dec 28, 2015 03:09 PM
