Re-doing weatherstripping '87 IROC
Old Mar 19, 2016 | 04:24 PM
Kevman's Avatar
Car: 1987 Firebird Formula
Engine: 2004 LQ4
Transmission: T-5 WC
Anything I should do before I install the new seals on my T-tops?
I stripped off as much glue as I could, and used speedway 500 adhesive remover to get off the remaining bits of black stuff.. I also repainted after this pic was taken..
Is there any tricks to putting those seals on?
Old Mar 22, 2016 | 07:09 PM
Eagle223usa's Avatar
Car: 89 5.7 IROC/95 LT1 Corvette
Engine: All 5.7's
Transmission: 700R4 (Roessler)/ZF6
Axle/Gears: 10 bolt Zexel 3.23's. CTW 17" wheel
Re: Re-doing weatherstripping '87 IROC
Thats how my complete re paint started! Total lack of rust for a Canadian car!
Old Mar 23, 2016 | 10:29 AM
DonW's Avatar
Car: 1983 Z28
Engine: Carbed 305
You have probably already tackled this already, but if not, a couple of important things I can think of are:
Wire wheel any rust in the channel completely off and spray the area with rust converter.
Liberally use black silicone adhesive in the j-channel to keep water from getting under the new seals. Keep some mineral spirits and rags handy to wipe off excess.
Once the seals are installed and the silicone underneath has been wiped away and not visible, put the t-top in and lock it down. This will squeeze out more excess to be wiped away with mineral spirits on your rag. Then just take the t-top back out and let the seal relax on its own and dry for 24 hours before reinstalling the t-tops.
Worked for me last year, and is still leak free.
Old Mar 24, 2016 | 07:07 AM
Kevman's Avatar
Engine: 2004 LQ4
I used the 3m Weatherstrip adhesive, after recently doing the weatherstripping on my 72 Charger, I was sort of practiced at it..
I used masking tape to hold the seals back, the front fit nice, the rear had a gap.. So I glued the hell out of it, held it in place with masking tape, then after a day stuck the t-tops back on (it required two people..)
edpontiac91
May 18, 2016 09:43 AM
Streetstuff
Interior Parts Wanted
Apr 29, 2016 07:22 PM
gnilson
Mar 24, 2016 07:03 AM
Ricks88IROC
Mar 17, 2016 08:25 PM
