how does power antenna trim peice connect to mast?
Old Aug 16, 2016 | 09:13 PM
eddie jr's Avatar
So this is an 85. The car had a power antenna but it was broken and i got rid of it 14 or 15 years ago. Now i want to add it back for the clean look and all the searching i have done indicate they are the same for 82-92, however, this one (from an 83) has a different mounting bracket and i see nowhere the upper trim peice can screw into the top of the mast. What does the trim piece that goes down from the top (outside) of the fender screw into, the mast? It is threaded, so i assume that is what it would attach to, or is there another piece underneath that i might be missing?
Old Aug 17, 2016 | 12:12 AM
rarebmx's Avatar
Car: 89 IROC/89 Vert/87 Vert/89 GTA Vert
Engine: 5.7/5.0/5.0/5.7
Axle/Gears: 9" 2.77/9" 3:23/9" 3:42
Re: how does power antenna trim peice connect to mast?
There is a male threaded trim piece that threads into the female threads on te antenna mount. It is power antenna specific. In between those two is a washer that is at an angle to fit on the fender
Old Aug 17, 2016 | 12:38 AM
eddie jr's Avatar
I know the trim peice you are referring to but i don't know where it connects. THis is the piece your talking about:
Now look at this antenna from an 83. The bracket appears different and there is a top bracket thta goes above the height of the antenna mast which doesn't make any sense. But look in the tube, where would that bezel/nut screw into when it is not threaded??
Old Aug 17, 2016 | 01:43 AM
rarebmx's Avatar
That main unit is different than mine or any others I've seen. That msle piece is supposed to thread into the top of that main unit. That bracket at the top is strange. Sorry I can't be of help
Old Aug 17, 2016 | 09:32 AM
eddie jr's Avatar
That's what I'm thinking....weird. This came off an 83 but every advertisement I have seen shows 82-92 grouped together for power antenna stuff. However, my parts manual for the firebird generation shows that the parts numbers actually changed several times through the generation (must be small changes I guess).
Old Aug 17, 2016 | 10:13 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
I agree...very different at the top than my '88.
Drew
Jun 10, 2016 03:33 PM
Agent13
Exterior Parts Wanted
Apr 22, 2016 12:00 AM
86IROC112
Mar 29, 2016 10:23 PM
dhirocz
Aftermarket Product Review
Nov 5, 2001 11:54 PM
thunderstick
Sep 22, 2000 02:05 PM
