Sub frame contacters
Old Sep 5, 2016 | 08:02 PM
amshnock's Avatar
With my new 350 in my 88 iroc I'm twisting my body bad. I need to get sfc and found this on Summit but they don't say if the will fit.
https://m.summitracing.com/parts/upi...DUkaAjrE8P8HAQ
Wanted to know has anyone used them?
Old Sep 5, 2016 | 08:30 PM
daferris's Avatar
Car: One owner '88 IROC 50k
Engine: L98 with bolt ons.
Axle/Gears: 3:42 again
Re: Sub frame contacters
No the ones your looking at are 4th gen ones...
These are the ones that I have on my '88...
http://umiperformance.com/catalog/in...roducts_id=127
Old Sep 5, 2016 | 09:18 PM
Hal87's Avatar
Car: '84 Firebird TA & '87 Camaro LT
Engine: 350 V-8 & V-6
Axle/Gears: 3.23 & 3.42
That is what I put on my TA. With the T-tops they really help cut down on the squeaks
Old Sep 6, 2016 | 03:52 PM
amshnock's Avatar
With them I have to cut out my old control arm mounts?
I don't care if I do
Nvm I see the go around them to use both
Old Sep 6, 2016 | 05:32 PM
daferris's Avatar
No you strattle the stock mount the bolt goes thru there connector and the stock then you weld them together
Old Sep 7, 2016 | 07:54 AM
amshnock's Avatar
Thought so that's good. My driver side mount is a bit rusted.
Old Sep 7, 2016 | 03:49 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
If you are running a y pipe buy the UMI connectors. If you are running exhaust inside the transmission tunnel then buy the BMR connectors. If you or a friend or relative can weld then forget buying them and just make em. The outer connectors are very simple to make. The drivers side is a straight bar with two saddle joints and then another bar at 45* to the transmission tunnel. Look at the current last page of my build thread and you can see how they mount and look.
BG1959
Jul 20, 2016 02:22 PM
M3638
Interior Parts Wanted
Apr 24, 2016 07:19 PM
dmccain
Apr 23, 2016 12:49 PM
Prodigious
Apr 23, 2016 11:21 AM
90Camaro5speed
Apr 2, 2016 02:41 PM
