83 pop up headlight sticks when turning off
Old Nov 10, 2016 | 07:04 AM
eddieb4's Avatar
Does anyone know best way to fix a passenger side headlight that sticks when turning off headlights? Motor works hence the headlight will pop up but when I turn off I have to spin the *** next to the light to get it to close.
Any input would be greatly appreciated!
Old Nov 10, 2016 | 09:03 AM
luvofjah's Avatar
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
Re: 83 pop up headlight sticks when turning off
2 things to look at...
Inside the motors, there is a part that disintegrates... check out Top Down Solutions / TDS for parts to replace...
Other thing...
There is a relay box, near driver side / firewall that has relays for the up/down headlights... If this is faulty, could also be issue...
TDS also sells these, but try the 1st option, cheaper, especially if you've never messed with the motors before...
Rafael
Old Nov 10, 2016 | 09:04 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Eddie
Those little bushings in the motors are turned to dust. Get the rebuild kit from Lonsal at Top Down Solutions. That'll fix you up.
Common problem with these
