5.7 Tuned Port Decal Placement on rocker
Old Mar 28, 2017 | 05:44 PM
Galaxie500XL's Avatar
Car: 1988 IROC-Z
Transmission: T56 swap ongoing
Axle/Gears: 2.77 9-bolt Posi
The previous owner painted my car, and left off the 5.7 Tuned Port Injection decals that are placed below the IROC-Z emblems on the left and right ground effects.
From the photos I've seen it looks like the decals are centered left to right with the emblem on the rocker, but what I can't seem to find is how far below the IROC-Z emblem the decals should be placed.
Anyone know?
Any suggestions on prepping the rocker for putting the decal back on the car?
Old Mar 28, 2017 | 06:20 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: 5.7 Tuned Port Decal Placement on rocker
http://i117.photobucket.com/albums/o...ps802246d8.jpg
checkout this pic,this is from a totally stock Iroc Z,
it's the only one I could find quickly.
Old Mar 28, 2017 | 06:26 PM
mantaguy's Avatar
Engine: 5.0 EFI
As far as putting the decal back on,make sure the surface is clean,when I did mine,I used a product called SLIDE,it keeps the surface slippery until the decal is in place then you use the squeegee to remove the SLIDE.
Old Mar 29, 2017 | 12:20 PM
Croz's Avatar
Yes, center the decal under the badge. From the top edge of the decal moving up, measure to the opening or cut out in the rocker panel for the Z-28 emblem, dont meausre to the emblem itself.
From the top of the decal to this lower edge below the Z-28 I measured bang on 1/4".
Hope that helps.
Old Apr 4, 2017 | 08:04 PM
Car: 1988 IROC-Z
Perfect!
Thanks!
New Decal
Old Apr 5, 2017 | 02:16 PM
mantaguy's Avatar
Engine: 5.0 EFI
Originally Posted by Galaxie500XL
Perfect!
Thanks!
New Decal
,looks good
Old Feb 3, 2021 | 01:44 PM
GarageToys's Avatar
Car: 89 Iroc Hardtop
Engine: LB9 w/G92 Pkg
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt, 3.45
This was a hard thread to find so I'm bumping it to say thanks to Croz and make it easier to find for the next guy.
I realized after getting my car back from paint that the painter installed the Iroc Z rocker badges but not the TPI decals under them. They were still in an envelope in the console so now I have something to do.
Iroc drummer
Exterior Parts Wanted
Mar 8, 2009 04:16 AM
BlueZee28
Feb 10, 2007 09:48 PM
CEP89
Nov 16, 2003 10:36 AM
alex13507
Jun 6, 2002 05:36 PM
