Removing Door Moldings
Car: 92 Teal RS
Engine: 305 TBI
I just recently bought a 92 RS. I've seen a few posted here that have the door moldings removed and i really like the smooth look it gives. how much bodywork is required to pull that off?
Engine: 4++,350 & 305 CIs
Re: Removing Door Moldings
None if you have original/nice paint.
Car: 92 Teal RS
Engine: 305 TBI
How are they attached? they don't go through the outer door shell? my paint is in good shape, but i don't want to do damage, or create work i'm not prepared to do.
Car: 1988 IROC-Z
Transmission: T56 swap ongoing
Axle/Gears: 2.77 9-bolt Posi
They're glued onto the car...but if the car was ever repainted, you might want to think twice about removing the moulding, because it's very likely that the moulding wasn't removed...meaning there's a different layer of paint under them.
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
use a heat gun and go SLOW! i went too fast and pulled some paint off.
GM used double sided foam tape to hold them on.
Don't underestimate the protection they provide and the damage they can hide. Peeled the molding off my project car and found a crease all the way down the door, and rust spots where they repainted up to the molding and left cracked paint underneath open to the elements. It didn't look nearly as bad with the molding in place.
