Who knows how to remove the plastic piece on top of the door panel?
Old Jan 2, 2002 | 10:22 AM
elevario's Avatar
Car: 1992 RS
Engine: 3.1L V6
Does anyone know? I am retinting my window and need to get a little lower on the window. If you don't know what plastic piece I am talking about, it is the one on top of the door panel, the black one that is right under the window. Please help!
Old Jan 2, 2002 | 10:36 AM
David Petersen's Avatar
You have to remove the entire door panel as this is part of it by...
Removing the door handel bezel,power lock bezel,and mirror bezel with a torx bit, removing the door hand, then going around the bottom and sides of the panel, with 2 flat head screw drivers, pop the plastic retaners, roll the window all the way down and pusing in a slight downward motion push the top piece toward the outside of the door then rotate it out and lift the panel off. Hope this helps.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
IROCZDAVE (88-L98)
Aug 6, 2015 03:51 PM
