Eng harness connector
Old Sep 14, 2017 | 05:15 PM
KCG's Avatar
KCG
Car: 89 IROC
Does anyone know how to get this connector apart down inside the passenger side fender?
I can see the plastic clip on this side and assume there's one on the other side but I don't want to yank on this and break something.
Is there a screw thru the middle?
Old Sep 14, 2017 | 05:29 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Eng harness connector
There is a plastic u shaped clip on the kick panel side. This is a pass through connector the wires are glued into place in the wire separator.
Old Sep 14, 2017 | 06:26 PM
KCG's Avatar
KCG
Car: 89 IROC
Perfect! Thank You
Everything pulls right thru.
Are you 2 for 2?...
Will the vacuum lines for HVAC come thru this hole in the firewall?
You can see half the grommet, and the harness with a small piece of orange tape around it.
Old Sep 14, 2017 | 11:36 PM
Drew's Avatar
Yep, pop the grommet thru just like the harness.
Old Sep 15, 2017 | 08:00 AM
KCG's Avatar
KCG
Car: 89 IROC
Great! Thanks guys.
