Eastwood reds
Old Sep 19, 2017 | 01:57 PM
KCG's Avatar
KCG
Car: 89 IROC
Eastwood reds
Has anyone used any of the Eastwood reds to match the factory bright red?
GM WA8774 code 81 seems to be the number. Some years it's called Flame Red, then Bright Red and Bright Rally Red.
Their Pro Street Red has a picture of a 3rd gen with it. Not sure that means anything.
http://www.eastwood.com/eastwood-pro...-1-gallon.html
And they do have a Rally Red.
http://www.eastwood.com/eastwood-ral...allon-kit.html
Old Sep 19, 2017 | 07:24 PM
Billgluckman's Avatar
Re: Eastwood reds
Instead of trying to match bright red why not just buy bright red?
Old Sep 20, 2017 | 08:02 AM
KCG's Avatar
KCG
Car: 89 IROC
Re: Eastwood reds
I didn't see a Bright Red at Eastwood.
Or you referring to a custom mix from a name brand?
I'm in the "pick out paint stage" and was wondering if anyone used any of the Eastwood Reds that was the same Bright Red. And their experience with it of course. I haven't read anything bad about their base.
Old Sep 20, 2017 | 08:46 AM
Re: Eastwood reds
If you take that paint code to a store that sells paint they'll give you bright red and will probably cost the same as eastwoods paints. It sounds like bright red is what you want, right?
Old Sep 20, 2017 | 08:35 PM
KCG's Avatar
KCG
Car: 89 IROC
Re: Eastwood reds
Yes sir, bright Red. Most Eastwood gallons are around 200 bucks. A buddy just bought a gallon of PPG for 1000. Now I don't know what else may have been included in that. Is there that much difference in price? I want a quality paint.
Old Sep 22, 2017 | 10:43 AM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
Re: Eastwood reds
Are u using single stage enamel or base coat/clear coat paint?
Why bother buying on line unless it a lot cheaper than your local body shop supply house?
The last car I shot i used Limco single stage paint at a $100 a gallon.
Bought at the local auto body jobber.
