Converting To Power Locks
Old Jan 3, 2002 | 12:21 PM
Trevor K's Avatar
What would be involved in adding power locks to my car? Is the wiring already there? Anyone done this?
Old Jan 3, 2002 | 12:54 PM
1990IROC-Z's Avatar
I never did it on my f-body, but I did add a Spal Power Door lock kit to my '79 El Camino. It was easy; there were already holes where the factory actuators should go and the Spal actuators bolted in using them. No switches needed as the type I bought has a controller that is actuated by grounding signal from an alarm or by locking/unlocking either side. There are switches available as an option too. I didn't want to make holes in my panel for a non-factory looking switch - just **** that way. Spal is an Italian company - I bought it off e-bay for $39.99 + shipping from mendy0159@aol.com. I ordered it right after the 9-11 tragedy, and it never arrived - she promptly reshipped.
If you want factory look and sound (the Spal is really quiet compared to my IROC and my Astro Van) - I would imagine it would be pretty easy if you can find a donor car for actuator, linkage, wiring etc.
Old Jan 3, 2002 | 05:31 PM
Trevor K's Avatar
I was actually hoping to grab parts from a stock car at the wreckers to do this swap, since it would be cheaper. Plus, I know if I can take the parts off I can put them back on too
Old Jan 4, 2002 | 05:31 PM
Trevor K's Avatar
Anyone done this using stock parts? It's +2 tomorrow and I'm going to be at the wreckers anyways, so I'd love to know what I need.
Old Jan 4, 2002 | 07:33 PM
KlayBuRn's Avatar
ok i had manual locks on mine....heres what you need
wiring harnesses for locks, door lock actuators, and the buttons for the door, thats all i needed, i ran the wires from one door to the other under the dash, hooked up the switches, powered the harness with a +12v wire, wired the buttons, mounted the actuators, and used coat hanger to complete from actuator to the lock, and mine still works like a champ...
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
IrocBuzz
Camaros Wanted
Nov 20, 2015 11:29 AM
Jake_92RS
Aug 17, 2015 09:42 AM
