Hood release
Old May 5, 2018 | 08:38 PM
Fourutonvy's Avatar
Want a title? Post!
Car: 89 Camaro
Transmission: 5 speed
Hood release
My 89 RS Camaro release cable will not engage tried Wd 40 from under neath Need some advice Have even removed side mount inside car shredded cable and locked on vice grips .still no -go Any pics of actual release device would be helpful > Thanks
Old May 5, 2018 | 09:25 PM
NoEmissions84TA's Avatar
Re: Hood release
If you lay on your back and reach up to the hood release, you should be able to work the release lever with your finger. You need to move it in the direction of the driver's headlight. I can't say for sure this will work on your 89 Camaro, but it works on my 84 TA.
If the mechanism is gummed up, the lever will be harder to move.
Having another person push down on the hood in the area of the latch might help also.
Old May 9, 2018 | 07:21 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: Hood release
After you get 8it opened, get yourself one of these.
https://www.ebay.com/itm/82-92-Camar...ty!08051!US!-1
Old May 9, 2018 | 09:37 PM
antares57's Avatar
Car: 91 Firebird/88 Firebird/91 Formula
Engine: V6 3.1/V8 5.0/V8 5.0
Transmission: 4L60/700R4/4L60
Axle/Gears: 3.23/2.73/2.73
Re: Hood release
If you lay on your back under the hood release you should be able to reach the bolts that hold the release bar with an extension and a socket. Did this at a parts yard to unlock the hood on a Firebird. Haven't tried it on a Camaro.
tonys91rs
Exterior Parts for Sale
Apr 25, 2017 12:30 AM
Napster134
Exterior Parts Wanted
Dec 3, 2016 05:33 PM
Panthers1
Convertibles
Nov 17, 2016 01:05 PM
Sutliff01
Oct 4, 2016 01:34 PM
84Elky
19
Jan 10, 2015 07:39 AM
