Ground effect mounting brackets
Old May 11, 2020 | 08:46 AM
Firefighter84's Avatar
Car: 1992 firebird
Engine: sbc 350
Transmission: th 350
Im looking for brackets to mount my effects back on the car most of the bolts have rusted . That or different ways to repair the studs if you have pictures I would appreciate it !
Old May 11, 2020 | 09:04 AM
BuckyBadgerRS's Avatar
Car: 91 Rs
Engine: 327 SBC
Re: Ground effect mounting brackets
If the brackets themselves are intact and just the stud is shot, what you need to do is cut the stud flush with the bracket. Drill a hole in the bracket where the stud goes and then buy a carriage bolt and slide it through the hole. Tack weld the stud so it doesn't spin and get a nyloc nut and washer for the other side. Speed nuts that came factory suck anyway so in all reality this is an upgrade over factory anyhow. If you do not have the tools to do this then you'll likely have to buy replacement brackets, but be prepared to pay way too much for them.
Old May 11, 2020 | 09:08 AM
Car: 1992 firebird
Engine: sbc 350
I can hardly find new brackets lol so I think fixing the ones I have is a must is there a way to do it with out welding ?
Old May 11, 2020 | 10:18 AM
Car: 91 Rs
Engine: 327 SBC
Not really. If you wanted to ship them I could do it and ship them back. It might take a little while but it'd be way cheaper than buying a welder or new ones.
Old May 11, 2020 | 01:08 PM
battmann's Avatar
Engine: LG4 / turbo LQ4
Transmission: 700R4 / 4L80E
As Bucky said it will be best to make new ones. We had to fabricate new brackets for my ‘84 TA. We used flat stock and threaded rod. You can see pics in my build thread here:
https://www.thirdgen.org/forums/memb...ml#post5891099
Old May 11, 2020 | 02:37 PM
Car: 1992 firebird
Engine: sbc 350
Thanks guys ! I was able to remove the old studs , the brackets are salvageable so just have to get the new studs tacked on
CSiciliano1993
Feb 15, 2012 03:06 PM
danielmonster
Exterior Parts Wanted
Feb 3, 2011 12:45 PM
MetalliCamaro68
Oct 29, 2006 09:38 AM
MetalliCamaro68
Oct 29, 2006 05:31 AM
nick05
Jul 3, 2005 08:32 PM
