Help. Trans AmLettering in the wrong place?
Car: 1986 Pontiac Trans Am WS6
Engine: 383 Stroker
Transmission: TCI 725hp built 700R4
Axle/Gears: 94 Camaro 10 bolt. Posi 3.23
After looking at other 3rd gen Trans Ams online, I thought I noticed something weird about my car. On my front bumper where other cars have the Trans Am lettering on the right side of the front bumper. Mine is located on the left side. Same on the back bumper, other cars have Trans Am on the back right. Mine has it on the back left. Mine also says Firebird on the side, while others sway Trans Am. I checked the VIN, it is a real Trans Am. Wondering if there is a factory option for these weird lettering changes. And the service tag has fallen off and idk the options. I believe it is fully loaded.
Thanks, Sean
Thanks, Sean
Car: '89 GTA
Engine: ZZ6TPI
Re: Help. Trans AmLettering in the wrong place?
Thanks, Sean
Thanks, Sean
Probably was repainted, or at least the decals redone and installed incorrectly.
Engine: 383 Stroker
Engine: 383 Stroker
i don't believe it was repainted. But there are some spots where the paint is coming off. There seems to be a red primer underneath. Is this a possible sign of a repaint?
Car: '89 GTA
Engine: ZZ6TPI
The front decal is also too high and crooked. It's definitely not original. The Firebird decal on the side doesn't belong either, it should also say Trans am. I also can't tell if the sail panel bird is the correct one, but it's in the wrong place (common mistake when repainting and applying new decals). It's fairly common for incorrect decals, installed in the wrong positions after a car was repainted.
Car: '89 GTA
Engine: ZZ6TPI
It could be original paint, or maybe part of the car was repainted. Even if not repainted, the decals could have been redone at some point in the past.
Engine: 383 Stroker
The factory didn't use red primer. They used a gray e-coat primer. You might be seeing the clearcoat peeling off and the red basecoat underneath would be dull matt finish.
Thanks, Sean
Engine: 383 Stroker
Car: 89 Firebird
Engine: 355 TBI
Great looking car. No big deal just take the incorrect decals off, look at some pics on where they are supposed to go, and get the correct ones off e-bay to go back on if that's what you want. I love the bird on the hood!
Engine: 383 Stroker
Thanks Guy. That's probably what I'm going to do this winter. I love the bird too.
Car: '89 GTA
Engine: ZZ6TPI
It looks like a great car though. I'm not trying to pick on it, just answering your question on why the decals look different. You could leave the decals, or change them, either way it's a cool car.
Engine: 383 Stroker
No idea why, but it's typically just poor attention to detail. It could have been that the replacement decals were ordered from the dealer, in which case it would not be a kit, but each one individually ordered and the Firebird fender decal may have been mistakenly ordered instead of the Trans am decal. What also typically happens is whoever removes the old decals doesn't take pictures and measurements of the old ones and then when they go to put the new ones on, they do it from memory. Probably didn't remember that the fender said Trans am and not Firebird and thought "well, that's what the dealer gave me, so it must be right". That crooked Trans am decal on the front is just someone being sloppy in their work. It could have been a DIY job, or just a crappy body shop. If my car came back from a shop with the decals all wrong, I would certainly reject it and make them do it again, but many people just don't care and accept it.
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Engine: 383 Stroker
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
that Firebird decal on the front fender looks aftermarket / not original and the bird emblem on the sail panel looks like its too high as well.
Engine: 383 Stroker
Calderone
May 19, 2006 12:02 AM
