3rd Gen Rear Hatch Hinge Replacement
Old Feb 24, 2021 | 03:16 PM
sklearman's Avatar
Car: 1990 Trans AM GTA 1 of 78
Engine: 5.0L FI
Transmission: 5 spd manual. Rare.
Looking for input/advice. I ordered new rear hatch hinges from Hawks Motorsports for my 1990 GTA. I have seen a lot of threads, and watched a lot of video, on replacing these hinges. My question is this. Has anyone tried with the hatch closed and secured by the hatch motor pulldown, replacing each hinge from the inside, one at a time, but leaving them just barely finger tight to adjust. Then, releasing the hatch pulldown and getting the hatch aligned correctly. Then, with the hatch closed again and secured by the hatch motor pulldown, tightening the bolts down? No doubt the lifters have to be disconnect first but this seems easier than trying to remove that heavy hatch and risking the glass shattering. I can see that the original hinges are bent out of shape, which clearly is why the rear lip extends out 1/4" too far and the 3rd brakelight connectors have left marks just to the rear of the contact plate. Thanks in advance, Stu (the not a mechanic kind of guy LOL)
Old Feb 27, 2021 | 08:26 AM
sklearman's Avatar
Engine: 5.0L FI
Re: 3rd Gen Rear Hatch Hinge Replacement
Originally Posted by kaoikx
Might as well buy the new bolts from Hawks as well. Also, you can do this on your own, (minus the modification of the hole). You can use a broomstick or other to hold the hatch up while you work on one side at a time. It's not very difficult. Also note, I didn't hear him saying it, but it's very important you don't over-torque the bolts on the glass, otherwise you can shatter it. 192.168.100.1 192.168.1.1
Thanks - yes I ordered the bolts at the same time. Also bought a torque wrench to tighten to factory specs. Just wondering why the hatch needs to be open instead of swapping out the hinges from the inside with the hatch closed.
T-Ruxx
Mar 5, 2020 02:01 PM
BM2
Jul 26, 2014 11:55 PM
Heckler
Aug 23, 2006 06:20 PM
gmanuel
Dec 29, 2002 10:44 PM
