89 TTA - Spoiler loose
Car: 89 TTA
Engine: Turbo 3.8
Transmission: 200R4
I have an 89 TTA and I think it has a reproduction fiberglass spoiler. On the drivers side, I can shake the spoiler where it attaches to the clips, but on the passenger's side it is nice and solid. Is there a way to tighten up the driver's side where those clips are? I believe that is causing quite a racket (noise) and I'm trying to reduce them.
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
Re: 89 TTA - Spoiler loose
the aftermarkets are held on by clips at the tip of the wings i think..check that area!
Car: 89 TTA
Engine: Turbo 3.8
Transmission: 200R4
Car: 91 Trans Am Convertible
Engine: LB9 5.0 TPI
Transmission: 5 SPD
Axle/Gears: Posi Rear
Can you post a picture of your spoiler? If it is the same type as my '91, the center section is riveted to the trunk lid. It can be secured by replacing the rivet with one size larger.
Engine: 3.4 / 5.0
from what i have seen, they are just screwed into the spoiler. Try see if there are screws on the clips and see if they are tight
