Help!! Need P/N for Seals on T-Tops
Old Oct 23, 2021 | 10:42 AM
Fxd99harley's Avatar
Car: 1984 Trans Am
T-Top 'Curved' Flat Rubber that hangs down over top of Door Glass
Can't find it anywhere. For Left and Right T-Tops....
1984 Trans Am
Approximately 28 1/4" X
2" total on 90 degree curve.
The 90 degree curve is at 1".
Attached Thumbnails Help!! Need P/N for Seals on T-Tops-20211023_115019.jpg   Help!! Need P/N for Seals on T-Tops-20211023_115009.jpg   Help!! Need P/N for Seals on T-Tops-20211023_114917.jpg   Help!! Need P/N for Seals on T-Tops-20211023_114951.jpg   Help!! Need P/N for Seals on T-Tops-20211023_114837.jpg
Help!! Need P/N for Seals on T-Tops-20211023_114724.jpg
Old Oct 23, 2021 | 03:20 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: Help!! Need P/N for Seals on T-Tops
https://www.classicindustries.com/pr.../10198352.html
GM Part Nos. are 10198352 RH, 10198353 LH
NO.47
Old Oct 23, 2021 | 05:26 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Best to throw those old rubber parts out and use the upgraded hard plastic pieces listed above. You'll have to trim off the 4 nubs flush to make them work on 82-90 ttops.
Old Oct 23, 2021 | 06:44 PM
StratosFear1986's Avatar
Car: 1991 Firebird V6
Engine: LHO V6 N/A
Sweet, I need a set of these as well. Thanks for posting the info about the plastic option, I`ll snag some from Hawks
Old Oct 23, 2021 | 07:42 PM
Car: 1984 Trans Am
Thank you all for the Information and related mounting tips.
Looks like it will still be 'fun' getting them in place without messing other components up. Actually I had seen this Style Replacement but was unsure of using the Rigid Plastic but these look impressive.
Old Oct 23, 2021 | 07:52 PM
mantaguy's Avatar
Engine: 5.0 EFI
https://www.1aauto.com/1982-92-chevr...49/367216/1986
I actually got mine from 1A,When I ordered the complete weatherstripping kit it included some actual Genuine GM parts and those side rail strips were Genuine GM..Mine didn't have those tabs you have to remove.
Old Oct 24, 2021 | 05:44 PM
mantaguy's Avatar
Engine: 5.0 EFI
https://www.1aauto.com/1982-92-chevr...48/367213/1986
C.M.Jones
Jul 29, 2010 10:40 PM
Timinsk
Exterior Parts for Sale
16
Sep 4, 2009 08:27 PM
88TPI406GTA
Jan 11, 2004 02:36 PM
trance
Nov 28, 2003 03:31 AM
