How to adhere lower door trim that is not flush to door
Old Aug 17, 2022 | 07:20 PM
Blackdog36's Avatar
Car: 92 Z28
Engine: LS3
Transmission: TR6060
Axle/Gears: Strange S60 3.73
I have a few ground effect trim pieces that are not fully flush with car door. These are the pieces at bottom door. On either end they bow out from door a bit. What is best way to get them flush? I tried double sided gorilla tape and that worked initially. But after driving around one day, they loosened a bit. I have some 3m body adhesive tape I can try. I think part of problem using tape is that trim piece interior does not have a surface that is parallel with door. So in using tape, there is not much contact area. I may try more tape, making it longer across trim piece to get more contact area. Annoying since if I pry trim back a bit, it wants to sag away from door more.
Old Aug 17, 2022 | 08:34 PM
topduarte's Avatar
Car: 92 Heritage Camaro Z28
Transmission: auto
Axle/Gears: 3.23 Limited Slip
Re: How to adhere lower door trim that is not flush to door
Have u tried heating it up with your wife's/girlfriends blow dryer? It might have twisted/warped over 30 years.
Old Aug 18, 2022 | 10:06 AM
72buickgs's Avatar
Car: 1984 Trans AM
Transmission: 700-4r
Use a heat gun on the outside of the trim because u want to bend it inward. U may have to remove the trim completely to flatten it.
Vmaxkid
Interior Parts Wanted
Aug 1, 2007 10:21 PM
LoudmouthSS
Apr 25, 2006 09:06 PM
smokenasty
Oct 18, 2005 08:16 PM
Kevin84Z28
Oct 26, 2004 10:25 AM
cfirebird86
Feb 26, 2003 07:11 PM
