'92 Hood blister and headlight opening paint
Old Aug 27, 2022 | 04:59 PM
Icelander's Avatar
Car: '92 Camaro Z28 Convertible
Engine: 5.0 TPI
Transmission: Automatic
Axle/Gears: 2.73 Posi
I've just acquired my first Camaro. It's a black and tan 1992 Z-28 Convertible. At some point it was hit in the front-end and the front was re-painted. The headlight openings are currently gloss black and I'm under the impression that they should be flat.
Are the blisters supposed to be flat as well? They need repainting as water has been standing in the "vents" for years. Is this normal? Is there something I should do to to prevent the water from pooling up?
Old Aug 27, 2022 | 06:54 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Re: '92 Hood blister and headlight opening paint
Blisters are body color, vents are non functional, so water just stays put. Wipe/blow or whatever it takes to keep the water off. I believe the (correct) shade is satin for the headlight pockets, but definitely not gloss. They tend to go "flat" after a few years probably.
Pics? and welcome.
Old Aug 29, 2022 | 02:58 PM
navy02ws6's Avatar
Engine: LS1, LB9, L03
I did my headlight buckets in Trim Black -- I'd say Satin is probably correct. Not Flat, and not Gloss.
Old Sep 8, 2022 | 01:29 PM
Abubaca's Avatar
I agree with "satin" not flat/matte. With regard to Trim Black, if you're referring to SEM "trim black" I believe that's too much matte, and not enough "satin", for a factory appearance. I use SEM Trim for all kinds of trim, and when I painted my 89, I used SEM trim black for the headlight buckets and felt it was too matte. Not a final answer, just my opinion. ...and of course, that doesn't mean it looked bad, just (in my opinion) not quite factory.
Old Sep 8, 2022 | 02:21 PM
vinny R's Avatar
Car: 1991 Z28
Axle/Gears: 3:42 Auburn
Vinyl wrap is an option for this also. 3M makes a nice satin black and depending on the car color has a bunch of gloss options for the blister scoops.
Old Sep 8, 2022 | 04:10 PM
gt4373's Avatar
Transmission: 5-Speed Manual
Trim Black Ultra Has A Satin Finish
Old Sep 9, 2022 | 07:35 AM
Abubaca's Avatar
...that's the paint I was referring to in my post. While I use the paint all the time for various trim projects, I don't think it's got enough sheen for the headlight buckets.Needs a little more gloss in my opinion. That being said, it's great paint, easy to spray and flows out nice and even. Good stuff.
Dustytrix
May 8, 2015 03:45 PM
'Shifter
Oct 17, 2006 08:52 PM
vorgath
Dec 29, 2005 01:32 AM
kevo2k6
Oct 27, 2004 10:00 AM
1991Formula350
Mar 3, 2004 02:26 PM
