91 firebird ground effect bar removal
Hey guys im new here . i have a 91 firebird that i am removing the ground effects and unlike earlier models it has a metal reinforcement bar . it seems riveted in . is there an easy way to remove without grinding the heck out of that part of the car?
Car: 85 Iron Duke, 88 GTA and 92 TA
Re: 91 firebird ground effect bar removal
I don't know what you mean... all ground effects have a metal bar inlay which hold it to the body. You have to loosen the nuts from inside the car for every ground effect piece. But the earlier models have the same system...
Engine: 4++,350 & 305 CIs
There are big ones on the rocker panels, they are spot welded to the car.
Aaaah, now I understand what you mean. Yes you have to drill out the spot welds with a spot weld drill to remove these.
