My door weatherstrip solution for bad repro
Old Mar 27, 2024 | 07:38 PM
Rosco the Iroc's Avatar
Car: '89 IROC, '14 LTZ Burb, '18 H6 Outb
Engine: 355 TPI /w Vortec
Axle/Gears: 9 bolt 3.27
So like others, I could not find repro seals that are really reproductions of OEM. I got the Hawks set and frankly it sucks. The end blocks are too big and misshapen. The middle seal is too big and the wrong shape. Also the mounting plugs are too small and fall out. Reviews for others are not good. So Screw it I'll make my own. I happen to see some plain stuff with 2 sided tape, It's a closer match then the hawks.
From left to right you can see how they differ and the Hawks is too thick and solid and will never crush down.
Stock/OEM reproduction from Hawks/Gen of the shelf from Auto Zone
Even with the loss of size due to 30 years the replacement is way too tall and the mounts are wrong. So I got 8' packs and only needed about 6'. I left the large end fillers on the car and cut the rest off. It used 2 sided tape and it went on and followed the angles nicely. Most of all I don't need to cave the door in to get it closed. I used some weather seal glue to seal the ends to the middle and carefully cut so there was no gap on the ends.
the AZ part-
on the door it followed the hinge contours like a dream
I was then able to finally finish the rehab of the driver's door and put the new inside panel back on. The passenger side is next. Damm I can't wait to drive Rosco again.
brandenbanks
Jun 30, 2022 08:25 AM
RF503
May 18, 2021 12:19 PM
Jt41z4nZ28
Mar 28, 2017 12:45 PM
Monkie
Jun 8, 2001 01:25 PM
TransAm86
Dec 30, 2000 10:43 AM
