what is the GVM of a 1982 Z/28
Old Jun 7, 2024 | 10:13 PM
aussiesteve's Avatar
Car: 1982 z/28 Right hand drive
Engine: 377 AFR195 750DP Solid cam 10.25:1
Transmission: TH/350 3200 stall spohn conversion
Axle/Gears: 10 bolt 3.42:1 Eaton Trutrac.
Gross vehicle mass specs from GM GVM
i think thats the vehicle full tank of fuel and AVERAGE 4 people inside.
i need this info for registration in Australia.
Old Jun 8, 2024 | 08:58 AM
72buickgs's Avatar
Car: 1984 Trans AM
Transmission: 700-4r
Re: what is the GVM of a 1982 Z/28
Tank hold about 13 gallons of gas. Density is 0.75. Take 4 people at an average of 150 pounds. Then add the weight of the vehicle + fuel + people weight.
Old Jun 8, 2024 | 10:30 AM
Tom 400 CFI's Avatar
Engine: LT1, L400
Transmission: ZF6, T5
Axle/Gears: 3.45, 3.31
Is the sticker missing on the driver's door? There should be a sticker that shows the GVWR.
Old Jun 8, 2024 | 10:31 AM
Engine: LT1, L400
Also, I think "people" average closer to 200 lbs these days. Not that that has any bearing on GVWR's. The rating is the rating. It's up to the operator to determine how many fat people, luggage etc, the car can take before crossing over the max GVWR limit.
Old Jun 8, 2024 | 07:10 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Yep-drivers door sticker will show the GVW: looked at my car and the GVW specs were not readable. I have a 1982 road test article from Road and Track or the like,and the curb weight of 2 loaded '82 z28s were 3440 for the hardtop and 3480 for the t-top car. Youu are right about people size these days:I was 140 lb during my young adult years and my jeans size was often sold out at the stores-now days 30" waist might be special order
ur7x
Jun 23, 2007 12:42 AM
Justins86bird
Car Audio
Jan 7, 2003 03:27 AM
