My hood shakes, what can i do to fix??
Old Feb 6, 2002 | 03:14 PM
stuart69427's Avatar
Car: 94 Camaro
Engine: 3.4L
Transmission: 4l60e
My hood shakes will engine is running, what can i do to fix this??
is it the hinges?
btw, i have new support cylinders in there
Old Feb 6, 2002 | 04:31 PM
genyuschrist's Avatar
Did you check the bolts....2 connecting hinge to hood and 2 connecting hinge to body(through fender, i believe.
Old Feb 6, 2002 | 09:12 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
1) Tighten the hinge attachment bolts. 2) Check if the rubber hood bumpers (2 per side attached to a slot in the fender) are still in place. These are compressed by the hood when it is closed and keep it from vibrating. 3) You can adjust the one plastic rear and 2 front hood bumpers (they corkscrew into the metal of the hood (rear) or radiator support (front)). This should solve the problem. Lon
Old Feb 6, 2002 | 09:13 PM
z28onTweenkies's Avatar
Car: 1992 Camaro Z28 & 2k3 Cadillac CTS
Engine: LB9
Axle/Gears: 3:43
get a strut tower brace
Old Feb 6, 2002 | 10:02 PM
Car: 94 Camaro
Engine: 3.4L
Transmission: 4l60e
thanx guys for your help
btw - i have a v6 which is really tall, when you find a strut tower brace that fit over it, then we'll talk
Hotrodboba400
Dec 10, 2019 07:07 PM
88rscamar0
Sep 23, 2015 09:08 PM
Amillionoh7
Sep 5, 2015 11:44 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
SlowAZ28
Sep 2, 2015 05:19 AM
