radiator support?
Old Feb 17, 2002 | 07:03 PM
19WS6T/A91's Avatar
radiator support?
can anyone tell me how to get off the radiator support and upper tie bar? if so can you please tell me how?
Old Feb 17, 2002 | 07:16 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
(4) 10 mm bolts hold on the upper radiator support to the front sheet metal cross brace. Lon
Old Feb 17, 2002 | 10:20 PM
Ray Burrows's Avatar
Drill out the spot welds. About 1/4 inch drill. Time consuming. Will need wire feed welder to attach new pieces.
Old Feb 17, 2002 | 10:36 PM
19WS6T/A91's Avatar
thanks ray thats what i needed to know. i heard from this guy that i know at gm that you could put the new pieces on using bolts. is there any truth to this?
Old Feb 18, 2002 | 08:29 AM
From a structural stand point those pieces need to be welded in, otherwise and accident or impact the crush won't work as it was designed. If you look at the front of these cars having 4 frame rails, 2 at normal height of bumper and 2 uppers where the fenders bolt on are actually tubular structures that support the upper suspension. These need to be tied together in a rigid manner (weld), bolts will allow too much flex and give. Now to align and fit the pieces before welding, I have used pop rivets. The rivets are removed in the welding process and their holes welded shut. Vise grips work great for holding sheetmetal prior to welding, but if you are fitting hood and fender gaps prior to welding they some times interfer. Good Luck
Old Feb 18, 2002 | 08:45 AM
19WS6T/A91's Avatar
thanks, that was alot of help.
David
sheachopper
Jul 31, 2019 11:27 AM
91TTOPZ
Exterior Parts for Sale
Sep 20, 2016 12:42 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
