4th Gen Camaro Dash in 3rd Gen Camaro - HVAC Question
Old Mar 10, 2002 | 02:32 PM
multi-tasking's Avatar
I am trying to decide if I want to do this swap. I have mapped out all of the wiring except HVAC assembly. Anyone have any clue if the HVAC assembly (controls) will work with my 3rd gen HVAC system?
m-t
Old Mar 10, 2002 | 03:22 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
i have the 1997 factory service manual (got it for free from school ) i can look up the schematic, or better yet, i can scan it
then all you will need is someone to scan you a 3rd gen schematic
lemme know if your interested
Old Mar 10, 2002 | 04:22 PM
Thanks, but I have the 1993 Service manual. I have been able to idenify everything for the 93/97 but linking back to the 89 is hard. Was just hopeing someone has already taken the leap with a Camaro. If I have to I will buy the 97 HAVC system and install it also.
Again, thanks
v/r
m-t
Old Mar 27, 2011 | 10:28 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Re: 4th Gen Camaro Dash in 3rd Gen Camaro - HVAC Question
Was curious about this too. Basically i don't have A/C but looking to keep the heater box in the bay, and if i swapped the 4th inner hvac box what would I have to do to make it fit with the 4th gen dash? or is it just a bolt on and i'm good? Also the wiring, would it be best to grab the hvac wiring from a 4th gen and plug it in?
Old Mar 28, 2011 | 12:17 PM
Firebat's Avatar
The controls will work but the vacuum lines need to be modified in addition to the wiring. I used vacuum caps, cut off the capped ends, applied permatex 5 min epoxy to the inner side of them, and used them as vacuum line splices. I've tried searching but I know the vacuum line diagrams are on here somewhere for the dash swap. Also the 4th gen heater door cable will work but need to make a custom bracket or I believe others have used a heater door cable from another vehicle like maybe a S10.
Old Mar 28, 2011 | 07:38 PM
dynodanmanda79's Avatar
Car: 1989 IROC-Z, 1979 Malibu Classic
Engine: LSx 5.3
Transmission: MN12 6-speed, 4L60E
Axle/Gears: 4th gen 3.42
IIRC TPI TERROR is using a heater cable from an LT1 camaro
Frozer!!!
Jan 19, 2024 04:55 PM
Casey Meyers
Mar 2, 2016 10:46 AM
redmaroz
Aug 16, 2015 11:40 PM
reiderz iroc
Aug 13, 2015 04:57 PM
Vintageracer
Aug 11, 2015 08:13 PM
