Z28 hood on a berlinetta
Old Mar 22, 2002 | 05:18 AM
Nemesis's Avatar
Car: Modified 83 Berlinetta
Engine: 350 - 300hp
Anyone put a 82 z hood on a berl? Was wondering if there were any subtle differences in shape / angles of the leading edge of the bonnet in relation to the berl nosecone.
Also, anyone cut out the fake induction inserts on a 82 hood for improved cold air flow?
Thanks.
Old Mar 23, 2002 | 09:50 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
The Z hood should fit right on there with no modifications. You may need to adjust it after installing it in order for the hood to have the same "gap" all the way around,....... or maybe adjust the hood lock Up or down so the hood closes *just right*. I have place a Z28 hood onto several of my past berlinettas without a problem of any kind.
P.S. I would not recommend cutting the little cowls out as it will lead to water on (or in) the engine bay unless you come up with some type of modification to deal with the rain.
Old Mar 24, 2002 | 05:42 AM
Nemesis's Avatar
Engine: 350 - 300hp
Thanks John, that is reassuring. I would like to try to utilise the fake scoops if I can to try to reduce the underhood temp and act akin to cold air induction. Something like a semi circular ring that drops down around the air cleaner etc
Hotrodboba400
Dec 10, 2019 07:07 PM
Ranbo108
Sep 9, 2015 12:20 PM
Stryker412
Sep 7, 2015 09:11 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
SlowAZ28
Sep 2, 2015 05:19 AM
