disc/disc prop valve question......
Old Feb 4, 2009 | 03:54 PM
challenger71's Avatar
Car: 71 Challenger, 70 duster, 89 iroc,
Engine: hemi and 440
Transmission: a-833 4 speed
I just put in a 9 bolt posi rear into my 92 camaro rs. I went from rear drum to disc and bought a disc prop valve, I think. I bought it from a guy on here. I tried to see if it would fit where my existing one is located, but there are either some parts missing or I need another line. CHeck out my pics and tell me if this is a disc prop valve or not. If not I need one if anyone has one for sale.
Attached Thumbnails disc/disc prop valve question......-100_3790.jpg   disc/disc prop valve question......-100_3791.jpg   disc/disc prop valve question......-100_3792.jpg
Old Feb 4, 2009 | 04:35 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: disc/disc prop valve question......
That's not a thirdgen proportioning valve. Compare it to the one in the following pic:
JamesC
Attached Thumbnails disc/disc prop valve question......-dsc00003.jpg
Old Feb 4, 2009 | 06:14 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
I think it is an early style before GM went to aluminum valves in the late 80s, I saw one like that on a '84 or so car in the scrap yard. You can't tell disc or drum just by looking at them, the differences are internal.
In any case, replace it as it's iron, old, and likely very dirty inside.
Ed
Old Feb 4, 2009 | 06:28 PM
JamesC's Avatar
Not like the OE in my 85, and i've never seen one like it. I wonder if it's part of the 82-84 weirdness?
JamesC
Old Feb 4, 2009 | 10:53 PM
ebmiller88's Avatar
Possibly, and they're ugly as well. I modified one off a MCSS for a rear disc setup and it looked just like that.
Ed
Old Feb 5, 2009 | 06:24 AM
I am not sure what it is off too. I am trying to get my money back on this one, because it obviously doesn't work for my application. I don't know what goes into the front of it. It looks like another line, but I think a plug with a screw bleeder is suppose to go there. I bought this from CAMFIRE. Has anyone dealt with him before? Do any of you have a disc brake prop valve for sale?
Old Feb 5, 2009 | 07:03 AM
JamesC's Avatar
The threads may be SAE instead of metric (as the later cars were).
JamesC
Old Feb 7, 2009 | 05:14 PM
livewire's Avatar
Car: 1983 Z/28
Engine: Edelbrock 355
Axle/Gears: 3.42/Zexel/PBR
its a prop valve from a 82-83 Car. possibly 84 as well but i'm not sure on that. I do know that my 83 has one identical to it, I pulled one from a 82 disc/disc car for my disc swap and it is identical as well. as mentioned before there is no way to tell if it is from a disc car by looking at it, and yes, those older steel prop valves are SAE fittings. I had to make custom lines going from the prop valve to the MC because I'm running a LS1 master which is metric.
Old Feb 8, 2009 | 08:05 PM
thanks for all your help. The guy I bought it off of is taking it back and sending me a newer style one.
Old Nov 20, 2010 | 01:38 PM
KnightmareCS's Avatar
Car: 82,83,99 T/As
Engine: 350,350,383
Transmission: ST-10,700r4,4l60e
Axle/Gears: P-3.23,P-3.42?,P-4.10
I need to rebump this thread. Just reading through the forums and came across this.
My 83 had one that looks like the original post. That was on my drum car. I swapped in a LS1 rear and bought a replacement prop valve.
The one I bought was from a board members claimed 83 Camaro. It looked exactly like my drum one.
We had a problem installing it as none of the original lines were fitting it. The one I bought did not come with any fittings or lines. So we decided to take apart the old and new one to see if we could transfer parts from one to the other so I wouldn't have to change lines. The bottom unscrews off, but it took major force to do it. There's a spring and a pin if I remember exactly. I think they were identical, but I'll have to ask my friend as I don't remember.
I ended up using the replacement "disc" prop valve. I had to cut my original fittings and crimp on replacements. Funny thing is, it turned out to be metric. Which doesn't make sense as I read 82-83 are supposed to be SAE.
The brake pedal feels weird, but I'm not sure exactly how it runs as I haven't driven it much. Still working on it.
Any ideas what I have?
Old Apr 26, 2011 | 10:43 AM
83C_CamAroZ28's Avatar
Car: 1983 Z-28
Engine: 5.7 L
the one on my 83 camaro looks like that but it has sum sort of nipple on the back...anyone know wat it is?...
Old May 24, 2012 | 07:52 AM
Arvizu9618's Avatar
Car: 1985 IROC-Z Clone
Axle/Gears: 3.23 Rear Disc
This is the type of valve I have on '85 Z28 with drum brakes. Appeared to look original to the car. Fittings to MC and brake lines were metric. Plug for spring and valve are standard. I did a disc conversion and modded the valve with the stiffer spring. Fixed my brake problems.
Old Aug 8, 2012 | 05:51 PM
direngrey's Avatar
My 84 se had this iron prop valve with disk axle I swapped it all too my 87
Old Aug 8, 2012 | 06:37 PM
JamesC's Avatar
It's been reported that some of the old-style iron valves were converted to metric before the newer style, so you were probably a bit lucky.
JamesC
Old Feb 23, 2014 | 03:14 PM
83L69Camaro's Avatar
Car: 83 L69 Z28 T tops
Engine: 305 H.O.
Transmission: 5 spd
Axle/Gears: 3:73
JamesC,
Noticed the strut tower brace in your pic. can you tell me where you got it ? All i can find is one for TPI cars. Thanks
Old Feb 23, 2014 | 03:27 PM
JamesC's Avatar
Originally Posted by 83L69Camaro
JamesC,
Check Summit or Jeg's for QA1 5227.
JamesC
Old Feb 23, 2014 | 03:32 PM
Engine: 305 H.O.
Transmission: 5 spd
Axle/Gears: 3:73
Got it , Thanks for quick reply
Old Feb 23, 2014 | 03:37 PM
JamesC's Avatar
BTW, you might consider installing after market strut mounts (eliminating the rubber donuts of the OE) to more fully realize the benefit of the STB.
JamesC
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
Hotrodboba400
Dec 10, 2019 07:07 PM
IROCThe5.7L
Sep 17, 2015 07:48 AM
Necron
Brakes
Sep 14, 2015 12:45 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
