Testing Perdoch brake kit fitment on a CTW Motorsports wheel.
Old Nov 30, 2012 | 09:28 PM
  #101
rlewi771's Avatar
Car: 86 IROC
Engine: 350 ZZ4
Transmission: TKO-600
Re: Testing Perdoch brake kit fitment on a CTW Motorsports wheel.
The rotor looks to be an 8 x 7.00'' bolt circle.
The two areas i've had rubbing problems are:
The outer perimeter of the rotor (where the vanes are) coming in contact with the center of the caliper. After discovering that problem, my fix has been to slip a flat blade screwdriver in between the rotor and caliper on both sides to effectively leverage up on the caliper, and then torque the caliper to bracket bolts. Basically, using the little bit of slop that is there, I torque the caliper down as high off the rotor as possible. (poor solution, but it has worked for now) which also further lifts that pad surface off the top edge of the rotor, a problem you are all too familiar with
The second location, is the lower caliper to bracket bolt contacting the rear of the rotor. In my pictures above (poor quality Iphone pics) you will see the area where the pads don't sit on the rotor, there is a freshly rubbed stripe around the rotor. That is from the lower caliper to bracket bolt, where the bolt extends through the bracket. I initially believed this was due to the looseness in the one bad hub, but it is on the other side of the car as well (where the hub is still good). Basically it's a very tight tolerance right there and having some play in the wheel bearing will cause it to rub for certain. I cut a thread or two off the bolts to where I still have full thread engagement, but not additional bolt sticking out of the bracket, and that seems to have cured that.
I'll have to give some more thought as to which direction I want to go. I know I could go C4HD through you and have an excellent fitting kit, I just hope the performance will be up to par. I dont feel like i'm very hard on my brakes even on the track, and have heard other road racers having success with the comparable c5/c6, so it might be worth a try.
I appreciate all the info
Old Dec 1, 2012 | 03:14 PM
  #102
87350IROC's Avatar
Car: 87' IROC
As we talked about in the PM's, the C5/C6 rotor is an option as well. I'll see if I can come up with a cad model of the design and send it over this weekend.
Old Dec 8, 2012 | 06:05 PM
  #103
87350IROC's Avatar
Car: 87' IROC
For those of you who appreciate the details. Some pictures of the brackets and hardware.
Right click - view image for larger
These holes are only 0.01" oversized to ensure there is minimal slop in the connection. This also helps prevent pad to rotor misalignment due to excess bolt play.
Old Dec 9, 2012 | 12:17 AM
  #104
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
That... is some good stuff.
Old Dec 10, 2012 | 06:47 PM
  #105
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
damn man, those are going to be some really hi class kits!
Old Dec 15, 2012 | 07:08 PM
  #106
87350IROC's Avatar
Car: 87' IROC
Only the best for my third gen friends.
Old Dec 15, 2012 | 07:13 PM
  #107
87350IROC's Avatar
Car: 87' IROC
Crappy weather today, but here are some pictures of the brackets. They are in various state of completeness. All have some finishing work to do before I would send them out to customers.
Right click - view image for a larger picture.
This is a machined finish.
Left to right, sanded, machined, bead blasted. Bead blasted is the standard finish.
Old Dec 17, 2012 | 01:43 AM
  #108
DBLTKE's Avatar
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
Looking good. When the time comes for my brake upgrade, I'm definitely going to get them through you.
Old Dec 17, 2012 | 10:10 AM
  #109
Zach/90\irocZ's Avatar
Car: 88 Formula, 90 Iroc RIP, 92 RS Sold
Engine: 305 to 350
Axle/Gears: 10 Bolt
Not bad coming along nicely. Is perdoch brake going to have a website soon ? or just word of mouth now..
Old Dec 17, 2012 | 10:51 AM
  #110
87350IROC's Avatar
Car: 87' IROC
Thanks for the kind words.
I will have a website eventually. It turns out I'm better at making brake kits than websites.
In other news. I did some basic testing of the ARP bolts over the weekend. A standard grade 8, 7/16-20 bolt has a torque spec of 75 ft-lbs. I maxed out my 150 ft-lb torque wrench without damaging the bolt or the internal thread. So I'm really happy with that result. The ARP is a good bolt for this application.
Old Dec 17, 2012 | 11:25 AM
  #111
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
Is this the kit you are making up for my GTA?
Old Dec 17, 2012 | 11:59 AM
  #112
87350IROC's Avatar
Car: 87' IROC
It is the same fitment but those are not your actual parts. The parts in the pictures are all mock up parts. I got your spindles and brackets done last night. Everything came out great.
Old Dec 17, 2012 | 12:24 PM
  #113
Engine: 305 to 350
Axle/Gears: 10 Bolt
wow 150 ft-lb and not even damage threads thats pretty impressive
Old Dec 18, 2012 | 08:39 PM
  #114
rlewi771's Avatar
Car: 86 IROC
Engine: 350 ZZ4
are you using 7/16-20 for the bracket to spindle attachment? I know the kit I have through Ed uses a smaller 3/8-16.
If so, how do you feel about that larger 7/16 on the top hole in the spindle, enough meat up there?
Old Dec 18, 2012 | 09:23 PM
  #115
87350IROC's Avatar
Car: 87' IROC
Yes, for the Wilwood kit, all bolts, bracket to spindle and caliper to bracket are 7/16-20.
So far I have been using all of the later spindles that have more meat on the upper hole. So in that case, there is plenty of room for a 7/16" or even a 1/2" bolt.
The earlier spindles have a smaller upper boss and taping to 7/16" does make the edge margin quite sporty. My mock up spindle has the smaller upper boss. I am not yet sure how I feel about this. As a result, I am trying to use only the later spindles. It is a pain and more costly doing it this way, but I feel better about it.
Now granted the further down into the hole you get, the more meat there is. So in reality I don't expect any problems.
I'm not sure how I feel about a 3/8" bolt either though. I would need to do some analysis. Obviously you are running them with no issue, and you test them better than most. With a quality bolt like the ARP you may be able to get away with a size smaller.
Mounting boss size comparison. That is a 1/2-20 hole on the left spindle. And an unmodified early spindle on the right.
Old Dec 18, 2012 | 10:12 PM
  #116
rlewi771's Avatar
Car: 86 IROC
Engine: 350 ZZ4
thanks, I like the sounds of the 7/16'', maybe I need to go to the pick 'n pull and look for some later spindles.
On a side note, got my hubs from Kore3 as well as the bearing pre-load spacers. Good stuff!! I'm starting to mock up and get some stuff put back together, i'm looking forward to seeing how it all turns out.
Your kits are lookin real nice by the way, I wish they were an option when I bought mine a couple years ago. Once this one is tired, i know where i'll go
Old Dec 19, 2012 | 02:38 AM
  #117
87350IROC's Avatar
Car: 87' IROC
Excellent. I knew you would like the Kore3 hubs.
The large boss spindles are 90-92. If you are unsure of the year, it is hard to tell the difference until you remove the rotor dust shield. And if you find an extra pair, let me know.
Old Dec 20, 2012 | 02:43 AM
  #118
Nelz's Avatar
Very nice kit!
Old Dec 20, 2012 | 02:53 AM
  #119
Nelz's Avatar
Do the Wilwoods in your kit use an off the shelf pad? I remembered that back in the day, sometimes when you bought a wilwood caliper, you had to go back to wilwood to buy a wilwood pad. This made it harder for me as I live in Canada and it sucks waiting for parts before you can do maintenance. (That's another reason why I chose to stick to the stock mediocre brakes rather than upgrade.)
Old Dec 20, 2012 | 11:54 AM
  #120
87350IROC's Avatar
Car: 87' IROC
The 7420 pad is probably the most common brake pad plate out there for aftermarket calipers. They are used by Wilwood and AP.
I however am not aware of any OEM application of the pad, so you will not likely find the pads at your local parts store. You MIGHT find them in a speedshop in Nascar country.
I don't see this as a huge problem however. The pads are 0.8" thick and should last forever on a daily driver. If you take care of your stuff, you will have plenty of warning that the pads need to be replaced.
Remember its not just a Wilwood pad. And many many companies make compounds for this plate.
John
Old Dec 22, 2012 | 09:00 PM
  #121
87350IROC's Avatar
Car: 87' IROC
Here are some updated pictures on Paul's kit. Again this is the Wilwood FSL caliper on the C4 HD rotor.
As always, right click - view image for a larger version.
Old Dec 23, 2012 | 05:10 PM
  #122
paul_huryk's Avatar
Can't wait until I get them!
Old Dec 23, 2012 | 05:14 PM
  #123
Twin_Turbo's Avatar
Does that dust cap fit a stock hub?
Old Dec 23, 2012 | 05:44 PM
  #124
Engine: 305 to 350
Axle/Gears: 10 Bolt
Wow talking about a complete package and no annoying trips to the auto store
Old Dec 23, 2012 | 09:52 PM
  #125
87350IROC's Avatar
Car: 87' IROC
No. There is an o-ring groove cut in the aluminum hub to accept the o-ring on the cap.
Old Dec 27, 2012 | 10:36 AM
  #126
87350IROC's Avatar
Car: 87' IROC
A few assembly pictures.
Old Dec 27, 2012 | 10:40 AM
  #127
Twin_Turbo's Avatar
That is super clean, awesome to see someone who is proud of his stuff and shows it!
Old Dec 27, 2012 | 10:05 PM
  #128
87350IROC's Avatar
Car: 87' IROC
Thanks.
Old Dec 28, 2012 | 02:42 AM
  #129
Nelz's Avatar
Do you have access to the new ZL1 Brake kit to see if it will fit?
http://fastlane.gmblogs.com/2012/12/...e-customizing/
Old Dec 28, 2012 | 08:43 AM
  #130
87350IROC's Avatar
Car: 87' IROC
The ZL1 fitment is identical to the '09+ CTS-V. This is the setup that started this whole brake adventure for me. This setup is going on my car.
The only difference is the color of the caliper and the ZL1 uses the same 2pc rotors like the '13+ CTS-V.
There are some complications on the fitment that I am working on making easier. For now this kit is special order only.
Old Dec 30, 2012 | 09:22 AM
  #131
87350IROC's Avatar
Car: 87' IROC
Here are some completed pictures. Again, right click - view image for a larger version.
Old Jan 4, 2013 | 11:00 PM
  #132
brdofpry85ta's Avatar
Car: 1985 Trans Am
Engine: 6.6 at least
Transmission: T-56 (waiting)
Axle/Gears: 9" w/4.56 & spool (4 now)
That is some top notch workmanship.... I have been eyeball'n wilwoods brake kits for some time now. But they don't offer 13" rotors.
The kit you have put together for Paul look awesume....now what kind of $$$$ will that set someone back....and does the customer supply the spindles.
Old Jan 4, 2013 | 11:54 PM
  #133
87350IROC's Avatar
Car: 87' IROC
Shoot me an email.
For complete kits I supply the spindles and you return your old ones as a core.
Or I can supply just the brackets and hardware and you supply the rest.
John
john@perdoch.com
610-554-6503
Old Jan 5, 2013 | 04:31 PM
  #134
Car: 1985 Trans Am
Shoot me an email.
John
john@perdoch.com
610-554-6503
Email shot....
Old Jan 9, 2013 | 07:35 PM
  #135
rlewi771's Avatar
Car: 86 IROC
Engine: 350 ZZ4
finally made it out to the junkyard, there were probably about 5 thirdgens, only 1 in the 90-92 range so i snagged them for myself. If I come across more in the future i'll let you know. Removing spindles at the junkyard without a spring compressor or floor jack is fun!
Old Jan 9, 2013 | 09:17 PM
  #136
87350IROC's Avatar
Car: 87' IROC
Excellent, I'm glad you found a set. You know why I pay people for the spindles rather than pulling them myself.
Are you going to drill them for 7/16 hardware? You could also drill them to 1/2" but I don't really see the point since the calipers use 7/16" hardware.
John
Old Jan 9, 2013 | 11:24 PM
  #137
rlewi771's Avatar
Car: 86 IROC
Engine: 350 ZZ4
7/16''
Old May 4, 2015 | 06:45 PM
  #138
GMan 3MT's Avatar
Car: 1986 Z28
Transmission: T5 WC
Axle/Gears: 3.42 T2R
John, was there any progress on this? I'm looking at buying 2 kits. A 14" SS using a 1le hub setup for my streetcar, and a Wilwood/C5 setup using a 1le hub. Sent you a more detailed email and it bounced.
On topic, one of the guys I race with in CMC has these CTW's. They're performing well so far. I may eventually get a set, but other upgrades have priority first, like brakes and shocks.
Old May 4, 2015 | 07:40 PM
  #139
paul_huryk's Avatar
I'm guessing you are talking about Sean, right?
Old May 4, 2015 | 08:44 PM
  #140
GMan 3MT's Avatar
Car: 1986 Z28
Transmission: T5 WC
Yup. I think you said it in a post earlier, the black look 10x better in person than they photograph.
Taken a few weekends ago at Texas World Speedway.
Old May 5, 2015 | 09:52 AM
  #141
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
What would be the minimum amount of clearance between the wheel and the outer part of caliper that would still make the wheel usable? The internet seems to think 2(ish)mm is the right amount, just curious if you guys agree.
Chuck
Old May 5, 2015 | 02:34 PM
  #142
paul_huryk's Avatar
The black does look better, but the silver is the better of the two - it has a great shine and is great for contrasting on dark cars.
uote=GMan 3MT;5912112]Yup. I think you said it in a post earlier, the black look 10x better in person than they photograph.
Taken a few weekends ago at Texas World Speedway.[ quote]
Old May 5, 2015 | 11:28 PM
  #143
87350IROC's Avatar
Car: 87' IROC
Chuck
Brembo recommends 3mm. I would not hesitate to run it at 3mm. Do you have an application where you are trying to run it at 2mm?
Old May 5, 2015 | 11:37 PM
  #144
87350IROC's Avatar
Car: 87' IROC
Hi Gary,
Sorry for stringing you along. I have not worked on this. I am not touching production kits with the 14" SS stuff. I am curious about the desire to use the 1LE hub. Specifically speaking, I do not use 1LE hubs. Rather I use aluminum hubs that have the larger bearings of the 1LE but with the offset of a normal hub. In this case building a kit around the C5 rotor should be pretty easy, but would be a one off custom job.
John
Old May 6, 2015 | 08:18 AM
  #145
GMan 3MT's Avatar
Car: 1986 Z28
Transmission: T5 WC
Shame to hear about you not making the SS kits. Your work looked top notch with attention to deail.
When I said 1le hub, (what I really meant was an alum hub with the same specs as the 1le), it was for three reasons, the bearing size, the offset and spares. I could never verify if the Kore3 hubs used the larger bearings or not, but sounds like they do. That's good.
May not be the correct line of thinking, but the +.316" offset in the hub would mean a slightly reduced thickness of wheel adapters since I'm planning on vette wheels on both cars for the time being.
For the racecar, it's already going to be 2-2.25" adapter to try get the max legal trackwidth. Every bit I gain from the hub/rotor, the less I have to use on the adapter. Even Sean with the CTW wheels still uses a spacer that that little bit extra trackwidth. <-- On topic part of this post
For the street car, it's purely cosmetic. A thinner adapter (I think it should be around 1.5") looks better behind the wheel, and brings the purty calipers closer to the wheel face.
I thought I read somewhere the SS kit required a 1le offset hub. This page shows that, tho utilizing a different rotor, so may not be accurate.
http://lukeskaff.com/?page_id=333
So if that has to use a 1le hub, it would be nice for the racecar to use the same, so worst case if something failed, I could borrow the streetcars hub for the racecar. I've also got a pile of cracked 1le rotors that could be cut down.
Prefer the C5 rotor over the C4HD because I'd rather have the extra thickness than marginal diameter. I'm tired of repacking the bearings every time I cracked a rotor. I do have ducting, tho it's not the greatest shape anymore. C5 rotors also have the upgrade-ability from companies like GyroDisc and StopTech.
All that said, I realize the Wilwood/C5/1le combo may not be possible. The hub simply may just have to be the std offset.
Big thing with both setups, I really want to avoid having to modify the calipers themselves.
Old May 6, 2015 | 08:28 AM
  #146
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Axle/Gears: 3.79
Thank you for that info. I see Tirerack also recommends 3-4mm.
I have 17x9 OEM 10 spoke SS wheels that I test fit over my gen 1 CTSv setup. They cleared, but I never measured because I put 18" C6 wheels on.
Now that the car is in good enough shape to start autox'ing again, I think I'd rather run the 275s on the front I can fit on the 17" SS wheel vs. the 245 on the 18" C6 wheel.
I am away from home for the next week, when I get back I'll measure and see what clearance there is.
Old May 6, 2015 | 10:04 AM
  #147
the_hamturdler's Avatar
Man that's exciting to hear they might clear. I have a set of 10 spokes in the garage I'm trying to sell but if they clear I can actually use the ctsv calipers I got a smoking deal on.
Old May 6, 2015 | 11:24 AM
  #148
paul_huryk's Avatar
quote=Chuck!;5912714]Now that the car is in good enough shape to start autox'ing again, I think I'd rather run the 275s on the front I can fit on the 17" SS wheel vs. the 245 on the 18" C6 wheel.[ quote]
You will see a night and day difference in moving up to a 275 front from a 245 in the autocross.
Old May 18, 2015 | 03:39 PM
  #149
propaintball96's Avatar
Your pictures are beautiful.
Old Jul 7, 2017 | 06:07 AM
  #150
91camarosRS's Avatar
Car: 02wrx/88 rs
Engine: 2.0L turbo/nothing yet!
Transmission: 4eat/waiting on a t56
So..... is this still a thing?
