My 98+ LS1 Brake swap
Old Jul 23, 2002 | 07:38 AM
scauffiel's Avatar
I've mostly gotten her completed, I just need to adjust the parking brake mechanism a bit better. For now, you can check my website under Suspension/Brakes.
I'll probably take the time out later to post some of the pix in this post just in case I lose my website or it's down or something.
S.
Old Jul 24, 2002 | 12:37 PM
89formula#1's Avatar
Car: 89 Formula
Engine: Carbed 5.7
Transmission: TKO-600
hey not to be off topic but how did u get your roof rails so clean when u did the weaterstriping?? also where did u buy it from and how much was it? oh and refering to the brakes, couldn;t u of just put in a fourth gen rear with the brakes already on it for the same price??
Old Jul 25, 2002 | 07:04 AM
scauffiel's Avatar
I used a wire wheel attachment in my drill. Took the stuff out lickety split - but you'll have to go back with a small wire brush for the tight areas. I got my weatherstripping from a guy off of ebay that sells them all the time - do a search there for it under weatherstrip. I could have replaced it with a rear from a fourth gen but my rear tires already stick out too much as it is and that would have exacerbated the problem.
S.
Old Jul 25, 2002 | 12:06 PM
Car: 89 Formula
Engine: Carbed 5.7
oh i see. well thanks for the weatherstrip tip and good luck with the brakes
Frozer!!!
Jan 19, 2024 04:55 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
NBrehm
Aug 25, 2015 11:49 PM
sreZ28
Aug 14, 2015 07:48 PM
reiderz iroc
Aug 13, 2015 04:57 PM
