Rear Calipers: Which side?
Car: 1992 Camaro RS
Engine: 305 V8
I just bought a Borg Warner 9 bolt rear end from a guy and I'm just about ready to put it into my 92 RS.
I noticed that if the rear end was installed, one caliper on the brake would be on the side of the wheel closest to the front of the car, and the other would be towards the rear.
I've never seen a setup like this. All calipers seen to be in the same position on rear ends. Is there an advantage/disadvantage do the way mine is set up?
I'm thinking the previous owner had some fitment issue or something and swtiched the positions...
Car: 1992 Camaro RS
Engine: 305 V8
You know, I have no idea what kinda of calipers they are...
The rearend came from a guy with an 89RS though. Should I switch the calipers to the same side? If so, should they be on side of the wheel closest to the front of the car, or on the opposite side?
While I'm at it, since I have drum brakes, will I need a proportioning valve to correct the pressue to the brakes? The guy that I bought it from didn't, but his car was a few years older..
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The first pic shows the cast iron version, others the alum PBR's:
https://www.thirdgen.org/techbb2/sho...hreadid=246768
JamesC
JamesC
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Ed
1992 Trans Am
May 10, 2023 07:19 PM
novaderrik
Aug 10, 2015 12:44 PM
