10 bolt drum to 10 Bolt disc Brake Swap
Old Dec 2, 2004 | 08:14 PM
91NiteRida''s Avatar
Car: 1991 Camaro
Ive been so confused ...Is this swap as easy as it sounds??if i find a camaro with a 10 bolt disc brake rear end,will it fit my 10 bolt drum rear end if i change all the parts out from the backing plate on out?Also i know have to get the proportioning valve but thats no biggie...Im just wondering if its possible to do what im thinking...To put 10 bolt disc brake parts from a camaro that i found at the junkyard to my 10 bolt drum brake rear end...All and any info will be greatly appreciated
Old Dec 2, 2004 | 09:34 PM
FndmntlsOfPimpn's Avatar
Car: 87 Formula
Engine: 350 tpi
Axle/Gears: Stock 9 bolt
yea basically that easy but itd prolyl be easier to jus straight up swap the rearends out just my
Old Dec 2, 2004 | 10:43 PM
Car: 1991 Camaro
yeah i know what youre saying but i got the rear end for free and it had drums...so i decided to convert it to disc because i located quite a few 10 bolts in the junkyard today..so instead of paying for the whole axle,im going to just pay for the disc brake components.
Old Dec 3, 2004 | 09:11 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
You'll have to modify the axel flanges on the drum rear end. Check the following link:
https://www.thirdgen.org/newdesign/t...reardisc.shtml
JamesC
Old Dec 3, 2004 | 11:18 AM
Car: 1991 Camaro
JamesC
thanks for the info James...my question to you is that the link you sent me is for a ls1 disc swap...Im not getting the ls1 discs but rather regualr rear 10 bolt discs for my rear...would the same apply??To me it wouldnt seem like i would have to change anything out since its both a 10 bolt being swapped and in the same era vehicle...
Old Dec 3, 2004 | 11:49 AM
JamesC's Avatar
I sent the link to demonstrate how the drum brake axel flange must be modified to accept disc brakes--doesn't matter if the brakes are third or fourth gen.
JamesC
hectre13
Dec 11, 2023 08:14 AM
Vintageracer
Jan 10, 2020 05:33 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
sailtexas186548
Jan 19, 2016 12:21 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
