LS1 frt brakes and Ronal Firehawks :-)
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Looks like they will fit, it is really close and if I would have had time I would have played some more.
More than likely still need the spacers/spacer for them but physically they clear everything, just getting a little too close for comfort.
Mine arent mounted with tires as of yet but threw the rim on the assembly while i was getting everythign squared away. Looks like using the supplied spacers or one of a slightly smaller offset would work. Inside rim clearance could prove an issue depengin on how you balance your wheels.
later
Jeremy
later
Jeremy
Car: A few
Engine: All Eights
Transmission: All kinds
Rrrrrrrrrr.
Here I was, hoping for pics...
I'll be doing the same brakes courtesy of Ed, but with Ronal R9s. Interesting that you mention the balancing. I usually have the tapeweights installed as opposed to the hammer-on-the-lip type. Might need to change how I have that done since the R9s are 16" and not 17"...
So, who cares about tires? POST PICS ALREADY. haha j/k
K
K
Cant promise anything, I'm fighting the weather to finish the car.
If I can get a digi camera and some spare time in between finishing the car on sat, I will try and take a few pics. I have no rubber for the 'Hawks yet, just the rims at this point.
later
Jeremy
later
Jeremy
dbrochard
Oct 3, 2015 12:43 PM
dbrochard
Sep 19, 2015 08:13 PM
