What size prop valve fittings?
Old Jan 15, 2005 | 03:14 AM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
I want to install my adjustable proportioning valve to proportion my rear brakes, but I need to know which size fittings the stock brake lines are for the prop valve and what adapters I'm going to need to buy. I got the adj. valve off ebay, but I think its identical to the one Summit sells.
Old Jan 16, 2005 | 01:40 AM
Car: 1997 Corvette
I'm sure some of you have installed adjustable proportioning valves. What adapter fittings did you need, and what size are the stock brake line fittings into the prop valve on an '88 TA? I want to have all the necessary fittings before getting the lines apart.
Old Jan 24, 2005 | 12:16 AM
Car: 1997 Corvette
Bueler....Bueler....Bueler....
I'd like to hear from anyone who put an adjustable prop valve on an '88 or older car (because of the differing thread pitches that came in some '89 and all newer ones). What did you decide to do with the lines? Did you just cut the stock lines and flare them with different fittings?
Old Jan 24, 2005 | 01:47 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Take a peek at this yet?
https://www.thirdgen.org/newdesign/tech/propvalve.shtml
toronto formula
Nov 10, 2015 06:17 AM
69 Six Pack
Oct 5, 2015 07:51 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
knight72
Aug 10, 2015 09:32 PM
