Rear disc swap.
Car: 89 Trans am
Engine: TBI 350 HO Vortec heads
Rear disc swap.
ok what all do i need for this?
can i just go buy all the parts from autozone (everything cept the rotors and pad i want good ones) and if so how much would that cost.
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
You do realize that this question was answered in a thread about 5 topics down. "Cheapest rear disc brake setup" or something along those lines..
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Not to be an *** but do a search for "rear brake swap" and you should get a lot of info. But I feel like typing so here's a short answer:
As for the parts, yes, you can buy all the parts at a dealer or a parts store but it will run you a lot, a whole lot. You can buy used setups or complete kits to swap the brakes over. Here's a short rundown of what you'll need:
rotors, calipers, carriers, carrier bolts, backing plates, pads, e-brake cables, 3 pc flex lines, 2 pc hard axle lines, banjo bolts, cursh washers.
Ed
Ed
Car: 89 Trans am
i kno, i skimmed the topics, and that cheapest rear disk setup, but i just wanted to know if i could buy all the parts new at autozone, or if they didnt offer it all.
You probably can't find the backing plates at AZ but you should be able to get the rest.
Ed
Ed
hectre13
Dec 11, 2023 08:14 AM
sailtexas186548
Jan 19, 2016 12:21 PM
